Upgraded XO Monitor 10s sound better w/ 2amp fuses?
RandyWilliamson
RandyWilliamson Posts: 178
edited May 2009 in Vintage Speakers
So I was occasionally blowing the fuses in pairs when getting a little crazy w/ volume....and I read somewhere that we're supposed to just bypass them...well I was hesitant....but was blowing them here and there....worked up to 1.5 amps and now to 2 amps fast blow....I think they sound different...is it possible?
Well I'm also playing from Media Monkey instead of windows media....and I have tweaked the EQ settings....de deh dedehhhhh probably the difference I hear.
Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss"
  • Face
    Face Posts: 14,340
    edited May 2009
    What are you powering them with?
  • RandyWilliamson
    edited May 2009
    er uhm eh a ssshhhh sony 5.1 (i beleive) system that has 2 channels that run 100w per.
    dont tell the elders....im working on it tho seriously.
    Benq W5000
    F1nut Posts: 52,406
    edited May 2009
    Turn it down before you fry the tweeters.
  • RandyWilliamson
    edited May 2009
    F1nut I have turned it down.....I am posting an amp thread...in search for clean power...that should stop this problem correct...?...please stop by the amp thread when you have a chance under electronics.
    Benq W5000
  • gdb
    gdb Posts: 6,012
    edited May 2009
    How LOUD are you playing them ? I've got un-modded 10As driven by an old Pioneer AVR (wpc-unknown). I can get them very loud and still not blow the correct 1amp fuse, ever.:eek::confused::)
  • RandyWilliamson
    edited May 2009
    20 out of 30 on my sony 100-110 wpc....is that too loud?
    i've heard many ppl tell me that a truly stable amp can provide truly loud playback just fine.....u dont suppose I'm driving too much power as is?
    Sony DE345
    Benq W5000
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Higher powered clean amps have better control over the speakers. If you are clipping your AVR you can be sending burst of damaging high powered distorted signals to the tweeters. Getting an amp will make it sound better at higher volumes, but even clean high power will fry a tweeter after the voice coils heat up. If you are after very loud tunes with an AVR get some big old Cerwin Vega's.
    Ben
    Ben
  • RandyWilliamson
    edited May 2009
    I like the SQ of the polks....the AVR is going out the door...im going to get a real amp....and maybe calm it down some on the volume if that's what you're saying.
    Benq W5000
  • Polkwannabee
    Polkwannabee Posts: 2
    edited May 2009
    I recently took possession of a pair of Monitor 10 sepakers, The previous owner says they worked fine when shipped but I only get sound out of the tweeters. No mids or base sound at all.
    Speakers could have been better shock insulated when packaged but only very minor dings occurred to a couple bottom corners, really minor.
    I plugged the same banana plug connectors into another pair of speakers and they pay fine.
    Are they repairable? Does anyone have an idea as to why this is happening?
    Any information would be appreciated.
    Thanks.
    David:
  • HB27
    HB27 Posts: 1,518
    edited May 2009
    FIrst guess would be that the mid woofers were damaged in shipping.
    I think you'll find out when you lightly push in on the Midwoofers that they're locked up. My experience with shipping the old monitors is the glue holding the magnets to the frame has dried out and the magnets have slipped locking the voice coils.
    Try pushing in on the midwoofers. they should move free and easily. IF not then they've gone bad and need replacing.
    Polk has a great replacement for them.
    If they move free and easily then pull out the midwoofs and make sure the wires are still intact and have not come off during shipping.
    Harry
