Hook up LR surr. or LR back?
monk2672
Two questions. I have a 7 channel receiver but only have room for a 5.1 set-up. The 2 Surr/Back speakers will have to be as far back from the listening area as the front and center speakers. When I connect the Surr./Back speakers should I connect them to the LR Surr. or the LR Back channel? I currently have TSi300's in front cs10 for center and PSW111 subwoofer. Anyone have an opinion on whether I should use TSi100's or OWM3's for my surround speakers?
Post edited by monk2672 on
Welcome. For 5.1 use L/R surround. What AVR are you using?
PaulyLife without music would♭ -
Thanks Pauly,
I'm using the Yamaha RX-V565. Any opinion on the speakers? -
id use the 100's in the back since they are matched with the 300's. You COULD use the OWM3's for surround backs if you want to go 7.1 in the future.
Good luck
Hi and welcome to the forum. I believe that if you put the speakers in the back, you would use the L/R Back connections vs the L/R Surrounds. Typically in a 5.1 situation, the surrounds go on the side. It might make a diference as to how they sound since the amp may process the signal differently based on where it is being projected from.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
No, you'd just use the regular surround outputs. The AVR's calibration will compensate for the placement of the speakers.
If you're running a 5.1 setup, there is no difference in how the surround channels are decoded, there's only one pair of surrounds, and only one way for them to be decoded.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
What are you smoking? I want some
Monk. See attached. Use Surrounds as prev stated.
