Bass from Audioquest Ruby
EFanning
I today upgraded from a mid-range interconnect to a used Audioquest Ruby equipped with upgraded RCA clips ($30, Agon). The bass is much better and often sounds like a bass guitar with good amplification, but I wonder if it dominates other instruments. Has anyone encountered a CD-amp interconnect like the AQ Ruby that delivered too much bass?
Marantz DV4001 CD and DVD
WD TV Live Hub with 1 TB (Need DacMagic)
Marantz PM7001 Integrated amplifier
Philips GA 312 Turntable
Polk Monitor 70s (Zone 1)
Polk Monitor 40s (Zone 2)
Post edited by EFanning on
You can never have to much bass. I've caught 13 bass on a good day with a purple plastic worm jigged from under a pier. I've never bout my worms from audiogon. Are the Ruby worms better?
Effin with ya.
Is there a sub in the mix? -
I did see some large mouth bass swimming from the speakers shortly after installing the Audioquest ICs. I just assumed it was the mushrooms, not the cables, causing that effect.
Anyway, there is no sub in the mix.
I guess the question is: Do Ruby ICs have a reputation for overemphasizing bass?
But the answer may simply be: The Rubies dish out noticable bass in my system. I must deal with it or buy new ICs.
If I played the bass, I might think these ICs were perfect.Marantz DV4001 CD and DVD
Polk Monitor 40s (Zone 2) -
I'm having the exact opposite problem, not enough bass when playing source direct without a sub. Im using using silver interconnects throughout. I'm going to experiment with some older IC's to decide if the lack of bass is a characteristic of ICs, speakers, or cdp.TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Pre/Processor - Emotiva MMC
Seven Ch AMP - Emotiva LPA
Fronts - Tyler Acoustics 7U's
Center - Polk LSIC
Sub - DSWPRO600
DAC - Music Hall 25.3CD - Marantz cc4001
Blue Ray - PS3
Speaker cables - Audioquest cv4 dbs
Interconnects - MIT AVT1's
Power Filter....Monster HTS 3500 MKII
