Bass from Audioquest Ruby
EFanning
EFanning Posts: 60
edited May 2009 in 2 Channel Audio
I today upgraded from a mid-range interconnect to a used Audioquest Ruby equipped with upgraded RCA clips ($30, Agon). The bass is much better and often sounds like a bass guitar with good amplification, but I wonder if it dominates other instruments. Has anyone encountered a CD-amp interconnect like the AQ Ruby that delivered too much bass?
Marantz DV4001 CD and DVD
WD TV Live Hub with 1 TB (Need DacMagic)
Marantz PM7001 Integrated amplifier
Philips GA 312 Turntable
Polk Monitor 70s (Zone 1)
Polk Monitor 40s (Zone 2)
Post edited by EFanning on
  • lightman1
    lightman1 Posts: 10,796
    edited May 2009
    You can never have to much bass. I've caught 13 bass on a good day with a purple plastic worm jigged from under a pier. I've never bout my worms from audiogon. Are the Ruby worms better?
    Effin with ya.
    Is there a sub in the mix?
  • EFanning
    EFanning Posts: 60
    edited May 2009
    I did see some large mouth bass swimming from the speakers shortly after installing the Audioquest ICs. I just assumed it was the mushrooms, not the cables, causing that effect.
    Anyway, there is no sub in the mix.
    I guess the question is: Do Ruby ICs have a reputation for overemphasizing bass?
    But the answer may simply be: The Rubies dish out noticable bass in my system. I must deal with it or buy new ICs.
    If I played the bass, I might think these ICs were perfect.
  • jabrax
    jabrax Posts: 315
    edited May 2009
    I'm having the exact opposite problem, not enough bass when playing source direct without a sub. Im using using silver interconnects throughout. I'm going to experiment with some older IC's to decide if the lack of bass is a characteristic of ICs, speakers, or cdp.
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
