Win XP computer will not shut down or reboot
danger boy
ok. i prob know the answer to this. but what the hell.
yeah. i go to reboot or shut off the computer with XP, and it just hangs on the final screen before going any further.
what, is a file missing or something?
i don't want to reformat the HD... but I guess that's prob the best way huh?
PolkFest 2012, who's going>?
Post edited by danger boy on
Is this a new problem or has it always been this way? And recent changes?____________________
Pool: Atrium 60's/45's -
started doing this several weeks ago. i don't remember if I did anything different to it since then. just one day.. it would not complete a reboot or shut down.. basically a restart. just hangs.PolkFest 2012, who's going>?
One way to deal with a problem like this, is to do a system restore. Just pick a restore point prior to this all happening. Keep in mind that if you do this, anything installed since then will be lost as well as anything you may have created ie; word documents. In some cases depending on how your configured, that is.
good luck"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
Whack it with a ballpeen hammer, Al.
I though reboot was when you had to kick it twice to get it to do something??? Huh.. -
Just make sure the system isn't doing any updates, sometimes, it will seem like it is hung up due to that reason. If not try system recovery.Shoot the jumper.....................BALLIN.............!!!!!
Who needs to shut down their computer?
I'd guess ther'es a program that's running that won't quit. Check your task manager, try killing processes before shutting down, see if it changes anything.If you will it, dude, it is no dream. -
danger boy wrote: »ok. i prob know the answer to this. but what the hell.
There isn't a file missing, usually when theres a file missing it won't boot up...or you'll get some sort of error message.
Theres a piece of software thats causing the problem, like Lasereath said....one thing you might try is to go into msconfig and disable startup files to see if that helps....Testing
Testing
Testing -
Press and hold your power button until it shuts down, re-boot and see if that clears the problem.
Bev's laptop did this last night.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
WebRoot SpySweeper would make my old laptop hang up on shutdown after AVG finished scanning. Sometimes it shut down....sometimes it didn't....
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Try looking in Event Viewer for an answer.
Also, open up task manager and then try and shutdown the pc. See what process is using a lot of memory or the CPU. -
So far I like your idea best.
ok cool.. what if in msconfig i have two of the same file? should there really only be one instance of a file not two?PolkFest 2012, who's going>?
that is the only way I can get it to reboot is to hold the power button and do a hard shut down.. which I'm sure is not good for XP.PolkFest 2012, who's going>?
If there was a windows system file missing(which I don't believe there is) you could put the xp cd in and go to run and type the following command sfc /scannow . This command will tell your os to search the disc for missing operating system files."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
danger boy wrote: »ok cool.. what if in msconfig i have two of the same file? should there really only be one instance of a file not two?
If there's 2 identical entries in msconfig then typically that means that there is 2 entries in your registry for that program/application.
I would use a program like CCleaner (totally free, totally awesome). Use it to clear out all the junk that accumulates from use. After the first section is complete, you'll see an option on the left side to clear up your registry.
Do it.
If that doesn't help, then shut down the computer manually (hold the button down for 10 seconds). Boot into safe mode (hit F8 after post, and before the windows loading screen).
Try shutting down/restarting in safe mode. If it lets you do it in safe mode, then it's a problem with a program that is running in regular mode.
If it doesn't work, it's a windows issue."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
quit visiting pornography sites.I am 100% BORN DEAF and No I am not kidding!
Why am I here? My wife's hearing!
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA -
CaligulaPolk wrote: »quit visiting pornography sites.
Hey...
HEY...
That's NOT cool man...not cool at all!"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
