Adcom 565 bypass mod. Correct??
fbm211
fbm211 Posts: 1,488
edited May 2009 in DIY, Mods & Tweaks
Here it is.I just want to make sure I got it right before I power them up.So let me know please.I will take any other suggestions anyone might have as well.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Your good. Just make sure you don't let those cap legs touch anything.
    Ben
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Thanks ben.Nothing blew up so later Ill see kow they sound.Its a little early and I dont want to piss anyone off.
    heiney9 Posts: 25,546
    edited May 2009
    fbm211 wrote: »
    Well ???
  • fbm211
    fbm211 Posts: 1,488
    edited May 2009
    Sorry for the delay. I almost took them out right at first.The first thing I noticed was a loss of bass slam,detail, and the highs were too laid back.The bass slam returned after a couple hours and I got back some of the clean sharp highs I like so much.The detail still seems a little lacking compared to without the bypass mod.It seems the dayton caps open up after only a few hours as I noticed with the rebuilt xovers so I will give them a couple weeks and then pull them out and see if I like em with or without.
    I will say however that this was a very easy and inexpensive mod to perform.
    edited May 2009
    Thanks for the post.............give them a couple weeks of burn in and see what happens. Not all tweaks work the same for each person.
