Jonesin
    treitz3 Posts: 20,069
    edited May 2009
    Translation in human terms?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2009
    treitz3 wrote: »
    translation in human terms?
    waaaaaaaaaaaaaaaaaaaaaaaaaa
  • hearingimpared
    edited May 2009
    dkg999 wrote: »
    The one RT1 has looks to be a great table. I would vote for maybe a better cart match with the rest of the system? Of course to properly mount the new cart you might need a slight tweaking of the turntable, which then in the circlular process referenced by RT1 gets you to the new turntable :)
    Four Words; NEW TURNTABLE, NEW CARTRIDGE!!!
    A VPI HRX and a Clearaudio Maestro . . . sorry for spending your money Big Bro.:D
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2009
    Tom,
    each must travel their own rabbit hole. Or......
    quantum physics analysis teaches us to look at natural systems order to understand the systemic problems and solutions to man made systems (like a rig) establishing a point of fixation for any part of the system outside the system introduces un-needed and unwanted variables. This is exactly what a wall mount does.
    RT1
    edited May 2009
    10-4.
  • reeltrouble1
    edited May 2009
    Spend all you want if the virtuality of it works for you, knock yourself out.
    Remember though a cirlce can get larger or smaller, however its area can never be exactly defined, it follows then no audio system is ever truly finished as it has no start nor an end as each piece is dependant upon the other. When viewed under these givens of interdependancy it is apparent there is no one part more important than another, no beginning and no end.
    RT1
  • dkg999
    dkg999 Posts: 5,647
    edited May 2009
    Ted - us marketing types just sum all that up as
    audio is a journey not a destination.
    DKG999
