Carver M-1.5t
    heiney9 Posts: 25,490
    edited May 2009
    zarrdoss wrote: »
    the house is 3 years old and it powers up fine upstairs but it does have a hum to it, but dont know if thats just because all I had hooked up to it was an I-pod to test it out with some crappy connect cables. will do a real test latter tonight hooked up to my power conditioner and everything. I know this house has some elec. noise to it.
    Yep, sounds like you have some wiring issues and perhaps the PS caps are getting weak in the Carver and perhaps the combination of the two senarios are causing the problem.
    Electronics sure are fun!!!!
  • zarrdoss
    zarrdoss Posts: 2,562
    edited May 2009
    also some of the hum is transfered to the speakers as well with nothing hooked up to it at all, F**ing fantastic!
  • Pinktulip7
    Pinktulip7 Posts: 249
    edited May 2009
    I would open the Cabinet see if anything wrong inside!!!
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • zarrdoss
    edited May 2009
    There is a electronics repair guy that is literally a stones throw away from my house and I just took it to him, I'm not going to mess with it, and I want to make sure it is working properly. Seems like a well made powerful amp so I'll put a little money in it.
