SDA SRS purchase
13»
  • lbristow
    lbristow Posts: 131
    edited May 2009
    I have mine about eight feet apart, and a couple inches from the wall, just enought to get the sda cable in. They sound incredible, I just need Ben to redo the crossovers if I ever get to taking them out. :D
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2009
    I think the pink wall might be messing up the soundstage.:D
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    Leroy, You are spot on about the wall... Wow.
    Lbristow, Do you have the first gen SRS's? How much does the crossover mod cost for Ben to do. I'm not sure I want to attempt it and I kow Ben does a great job.
    Thanks for the response,
    David
    I like to listen, tinker, listen and repeat.
    F1nut Posts: 52,008
    edited May 2009
    What do you guys think?
    Find another location on a long wall.
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    I moved the location to a longer wall (wife was thrilled, kids were excited) and I got a huge difference in the size of the soundstage and the difference in instrument placement was amazing even with my very ghetto modest setup.
    Thanks for the input!
    David
    F1nut Posts: 52,008
    edited May 2009
    You're more than welcome. Enjoy!
  • lbristow
    lbristow Posts: 131
    edited May 2009
    Bigbang wrote: »
    David
    they were built in 85, I do not remember what the cost is total, it is not too high though, I am wanting to say 4 or five hundred total. The only reason I am wanting to do it is I am not getting the cancellation signal from my left speaker, so I assume this will fix this. Ben probably thinks I am a moron since I have emailed him on and off to get this done, I just have never pulled them out yet, mainly because I listen to them every day.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    I do not think you are a moron. We will talk soon enough. I hear you about down time. I am in the works of a TL upgrade for them.
    Enjoy.
    Ben
    Ben
