Stuffing the interior of my Sub box.
Zurge
I have 2 12in subs. Should i stuff the box with polyfill or staple some insulation to the sides of the box? Will I be able to notice any difference in the bass?
Post edited by Zurge on
well, first, why are you stuffing ?
if you are stuffing for the right reasons, then are you aware of how much stuffing is appropriate for your application?
and lastly... you just put it in like your filling a grocery bag, keeping careful not to get any fill in the rear vent hole of the sub, nor to get any stuck in the basket of the sub.The Artist formerly known as PoweredByDodge -
I'd like 2 know the pros+cons of stuffin a box and also best materials.
Thanx....Testing
Testing
Testing -
what poly-fill does is it reduces resonance
i have my box built to .88 for my momos and i keep half a pound in each chamber to reduce resonance
some people say if your box is built to specs, then you dont need it
but it slows down sounds waves and such and it cancels out resonance which is why i use it
if you use about a lb for every foot^3, it makes your box seem something like 25% bigger
so if youre tight for space you can build a 25% smaller box, stuff a lb for every ft^3, and be good
not really sure of any disadvantages...
you have to pay the $5 at walmart for an 8lb bag...thats about it
materials for what?
-Cody -
Would the spray on Dynamat help? Or would something like the poly fill be a better idea?
Dyna-liner (spray on dynamat) inside the box is a waste of good dynaliner.
the box should be built well enough to not require the use of such a thing with the woofers in question.The Artist formerly known as PoweredByDodge -
okay so it's a good idea to stuff the box. By best materials i meant 2 say what would be the best stuffing for the box, any old foam, wadding or woteva.?
Cheers 4 the other info tho, it woz v helpful.Testing
Testing
Testing -
i think it is good idea...as far as best materials...go to walmart and get some poly fil...put about 3/4lb in for every sq foot
-Cody -
i still need to build a 0.6cu. ft. box for my sub but i've had a box sitting around thats about 0.53 or so cu. ft.. The documentation that comes with the sub says 0.6 cu ft w/ 1" polyfil lining. I'm assuming that i should just guild it exactly to specs instead of squeezing it into this box and stuffing it mindlessly (overexaggerating) fully of polyfil. Any comments?Testing
Testing
Testing
