banana plugs and speaker wire recomend
slowpolky
slowpolky Posts: 714
edited May 2009 in DIY, Mods & Tweaks
hi. i just bought an onkyo 607(aint here yet) to replace my htib . With the htib i used bare wire via spring clips. I have heard mono price is a good place to shop for cables and what not. Can you recomend what banana plugs and what kind of speaker wire i can buy to get an optimum connection
Post edited by slowpolky on
  • slowpolky
    edited May 2009
    whats the diff between 16 awg 14awg 12 awg . also with banana plugs closed screw vs open screw? i have rti4 and fxi
    treitz3 Posts: 20,134
    edited May 2009
    Hello Slowpolkie and welcome to the forum. Though you will probably get different ideas here in this thread, my suggestion would be to run a search in what you are looking for. There are two current threads on this very topic with hundreds of threads touching on the topic(s) mentioned.
    While you are awaiting answers here, you might want to take some time and read the various threads that already exist here in the Polk forum archives. If you have any further questions, feel free to post them here. Just a word of warning.....there is so much to read on this subject that you may be reading for the next 5 days straight.
  • slowpolky
    edited May 2009
    thanks buddy, i dont know how to navigate my way on here to look for stuff
    edited May 2009
    That's ok. We have all been there before at one point.
    Do you see the blue bar [could be grey or another color as I'm kinda color blind] that goes across the screen toward the top of the screen? It starts with userCP and ends with log out. Just hit the search feature toward the right of the bar and type in speaker cable, nanner's, banana or any other key words that you can think of. You might try the advanced feature to narrow down your search once you get the hang of things.
    Once you get a thread that deals with the topic you are looking for, read it for the information you want to absorb. That said, when you are done with reading that particular thread, look down at the bottom left hand corner of the page [you have to scroll all of the way down] and you will find related topics. I hope that this helps. If not, please let us know.
  • slowpolky
    edited May 2009
    i just found the search bar . omg!!! , theres like 500 threads lol. i tryed reading just a couple and close but no banana lol ,theres so much info
    edited May 2009
    Just type in "nanner's". Here's one that's recent dealing with that particular subject.
    http://www.polkaudio.com/forums/showthread.php?t=82542&highlight=nanner%27s
    You can either follow the other threads listed after you type in nanner's or just follow the related topics at the bottom left hand corner [all of the way down].
  • slowpolky
    edited May 2009
    thats the the one im looking at right now thanks, seems like i would be best with the screw type of banana plugs
  • slowpolky
    edited May 2009
    mono price has them cheaper than the parts expr
