Upgrading binding posts on an amp
tcrossma
tcrossma Posts: 1,301
edited October 2009 in DIY, Mods & Tweaks
I have a Pass Labs X-150 amp, which has what seem to me to be very basic and somewhat cheap binding posts.
My AQ CV-8 speaker cables have nanners on the amp end, and I had to buy some spades that thread over the nanners because the binding posts do not support the nanners. I don't know if the spade adapters or the binding posts are to blame, but I just can't get a connection to the amp that I'm comfortable with. No matter how hard I tighten the binding post, it comes loose if I move the speaker cable more than a tiny amount.
So, I'm at a point where I could A) do nothing and hope they don't pop off and short the amp. B) try some different speaker cables with different spades or C) look into replacing the binding posts. Is replacing the binding posts anything of a DIY job for someone without skills in that area (but willing to learn)?
Anyone have any thoughts?
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
  • unc2701
    unc2701 Posts: 3,587
    edited May 2009
    IIRC, if you unscrew the knobs on those posts all the way, you can pop out the plastic in the center and use bananas.
    If that doesn't work, yes it's very easy for someone w/o experience
    Backburner:Krell KAV-300i
  • tcrossma
    edited May 2009
    It's a solid knob, and I don't think it unscrews all the way -- all double-check on that tonight.
    Any idea how would I go about learning how to replace the binding posts? Some online guides, books, etc?
    Thanks.
  • unc2701
    edited May 2009
    1)turn it off
    2)unplug everything
    3)go make a sandwich
    4)open it up and pray that the caps have discharged
    5)the binding posts are going to either be held in place by some screws or have a large nut &washer holding them in (I'm pretty sure the X250 is the latter- can't remember if the x150 has the same posts).
    6)Once you've detached them from the chassis, you should be able to pull them out enough to de-solder the leads going to them. If not you'll have to do it from inside.
    7)find ones you like that'll fit in the holes. If this wasn't your first time or a nice amp, you could get into enlarging the holes, or making filler pieces to go smaller, but you should probably stick with the same size.
    8)solder the new ones on. Don't forget to put the lead through the washer & nut first, if it's that kinda post.
    9)screw everything back down.
  • tcrossma
    edited May 2009
    Thanks, that doesn't sound so bad. But I'm not sure I like step #4 all that much... :) Anything I can do instead of trust it to luck?
  • unc2701
    edited May 2009
    BTW, you might be able to pop out the plastic piece with it fully tightened, too (assuming that the posts are the ones I'm thinking of). I think those plugs are a UK thing- their power sockets are the same size as a banana plug.
    Step #4. If you power off with the speakers still attached (and your pre still feeding it a signal), this will drain the caps on a lot of amps very quickly. The other way to be sure is to hook a wire to a ground (socket, metal water pipe, etc) and touch it to the terminals on the caps- do this carefully. I'm erring on the side of caution here- as long as you stick to the binding posts and have it unplugged, you should be fine anyway.
    See link for directions on discharging caps:
    http://studentweb.eku.edu/justin_holton/caps_p.html
    That's in reference to tube amps- I think their design makes them more prone to holding voltage.
  • tcrossma
    edited May 2009
    Ok, thanks for the info.
  • CoolJazz
    CoolJazz Posts: 572
    edited May 2009
    On the class of amp that the Pass is, there is no question that you should put good posts on it. And I would highly recommend Cardas! If you had spades, I'd suggest the model they make that you turn one knob and it tightens both sides. They work really well and are very nice to look at! Forget shiny, supposed to be gold stuff and get the best...copper or the rhodium plated if you mind cleaning the copper a couple times a year.
    You can check to see if the existing are standard width by getting a double banana at some place like Radio Shack if you don't have one now. If it'll fit, then it's standard width. But the metal chassis underneath the existing can still not be agreeable. Remember that you need a good tight, stable fit so you can tighten down on the cable effectively. If the assembly isn't well mounted, then you can't expect an effective post to tighten down on the cable.
    So to replace...you may have to solder, drill and maybe nibble. Then you have to buy the right posts for the thickness of the chassis. And you need a soldering iron with enough wattage to heat up a big chunk of metal fairly quickly, so you don't melt stuff that's not supposed to.
    If any of that sounds uncomfortable then this probably isn't a job to tackle yourself. Good posts can be a joy to use and clamp securely, which is job one. Sounds like your existing are doing neither!!
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • schwarcw
    schwarcw Posts: 7,358
    edited May 2009
    As long as you buy gold plating over copper terminals you should be fine. Cardas makes high quality, gold standard products. For RCA terminals on your amps you can get quality gold on copper terminals for less money. Check out Parts Express. Vampire makes good stuff, as do others. Don't buy Rat Shack cheap **** gold plating over aluminum or even plastic. Pure junk!
    Carl
  • tcrossma
    edited May 2009
    Thanks for the additional info guys. I'll probably open it up at some point soon and see what it looks like in there, and then decide if I think I can do it myself or not.
  • Conradicles
    Conradicles Posts: 6,384
    edited October 2009
    Bump for more info.
    I want to replace mine on my old Denon POA-1500, but how do I know what size to buy?
