How did u connect Csi A6 with two(2)chanel Amp?
Pinktulip7
Pinktulip7 Posts: 249
How did u connect Csi A6 with two(2)chanel Amp?I want to connect Carver M-500T with Csi A6...:D::confused::D
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
  • pablo_rodz
    pablo_rodz Posts: 331
    edited May 2009
    I'm goin to guess... let's see if I got it right...
    From the pre-amp use a "Y" to the input of the Carver:confused: Then bi-wire the CSiA6
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
  • Ricardo
    Ricardo Posts: 10,634
    edited May 2009
    You could just use one channel, but some amps don't like to be turned on without speakers connected, so there might be a risk there. The Y splitter is a good idea; then connect one channel to the high side and one to the low side in the speaker (make sure you remove the jumper).
    SOPA
  • Pinktulip7
    edited May 2009
    I will try that.....is it going to make any difference over HK 7300?
  • Rocco1
    Rocco1 Posts: 190
    edited May 2009
    Pinktulip7 wrote: »
    Yes there will be better cleaner sound you will notice it.
    Does your amp have a mono iput and a bridgable option?
    Man Cave: 7.1
    -PS Audio Power Plant Premier
    -PS Audio Power backup
    -Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
    > Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
    >Sub = MK Audio 10'
    -PS3
    -Onkyo 5 disc cd player
    -Directv
    -Samsung 59' plasma flanked by 2 Samsung 43' plasma's
