How did u connect Csi A6 with two(2)chanel Amp?
Pinktulip7
How did u connect Csi A6 with two(2)chanel Amp?I want to connect Carver M-500T with Csi A6...:D:
:D
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
I'm goin to guess... let's see if I got it right...
From the pre-amp use a "Y" to the input of the Carver
Then bi-wire the CSiA6 HT:
Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
Living Room:
Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7 -
You could just use one channel, but some amps don't like to be turned on without speakers connected, so there might be a risk there. The Y splitter is a good idea; then connect one channel to the high side and one to the low side in the speaker (make sure you remove the jumper)._________________________________________________
I will try that.....is it going to make any difference over HK 7300?TV :>Panasonic TC-P55VT50
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
Pinktulip7 wrote: »I will try that.....is it going to make any difference over HK 7300?
Yes there will be better cleaner sound you will notice it.
Does your amp have a mono iput and a bridgable option?Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's
