need to run a new circuit for all this?
superjunior
superjunior Posts: 1,632
Was brushing through the instructions on my new xpa-3 today (thanks Metal) and it advises to run a sepperate circuit for the amp. I have all my gear plugged into a monster power 2550 power center which is plugged into a single outlet on a wall. That outlet is on the same circuit as a couple of other outlets in the room. These other outlets only power a lamp and sometimes a space heater in the winter. A buddy of mine advises I run a seperate circuit to that wall(which will be less than enjoyable)as do the instructions for the amp. The power center has specific plug ins for all componants, including a high current amplifier. The instructions for the power center(monster,go figure)doesn't cover this topic at all. This is one detail I haven't done any research on, and it really never occured to me untill dealing with the GIRTH of this amp. Any advise is more than welcome. thanks
jr
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
Post edited by superjunior on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    The heater takes up a lot. I would definitely run a dedicated circuit. While you are at it I would look at 2 circuits in a 2 gang box. The extra coin for the materials is all you should be paying if you find an honest electrician. Where are you located?
    Ben
    Ben
  • superjunior
    edited May 2009
    ben62670 wrote: »
    Ben
    I'm in the subs of clev. oh.
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    edited May 2009
    I'll throw the damn heater out :D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • ben62670
    edited May 2009
    A dedicated outlet is of more value than a conditioner in many cases. I need to get it done here myself. I was an electricain so it is just parts for me.
    Ben
  • superjunior
    edited May 2009
    ben62670 wrote: »
    well it sounds like a new outlet is probably the way it's gotta be. Is plugging my amp into the power conditioner (for now) out of the question? I won't be using the space heater or anything else on that circuit for months. Sorry for the dumb questions, I own a tree service and all my work is done outdoors, the only thing I know about electricity is to stay away from the primaries.
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • lightman1
    lightman1 Posts: 10,796
    edited May 2009
    Yep. A good dedicated 20 amp circuit will work wonders for the toys. Keeps out most of the interferances of anything else on a general use circuit i.e. heater.
    Ben.. DK had that write up on an in-wall conditioner duplex outlet. Can't remember the thread. Gotta link to for Jr. here?
    Russ
  • ben62670
    edited May 2009
    Does he have beer?
    Ben
  • lightman1
    edited May 2009
    ben62670 wrote: »
    Does he have beer?
    Good point Ben. A road trip may be in order to help the lad if he does.
  • acsubie
    acsubie Posts: 773
    edited May 2009
    i had been planning to add a dedicated line to my system since i moved into my house almost 2 years ago..guess what..just completed it this weekend! while i was at it i added 2! Took me and the uncle a couple hours and in all honesty if i had knowledge in adding connections at the circuit box i easily could have done it myself. Hardest part really was running the Romex to the new outlet spot.
    Now i have 2 dedicated circuits for my equipment:
    1- just for my EMO MPS amp with a power port premier
    1- just for my Power plant premier with a soloist premier. The power plant powers tv,avr,cable box,hd,ps3,squeezebox and MP 4k
    To be honest it has been a very expensive few weeks with the MPS, PPP, MP 4k, and the PS audio outlets...But my system is almost complete so thats good. As for the dedicated line i gave the uncle $100 bux for his time and materials so not too bad.
    Did i notice the difference? Well 1st of all my lights no longer dim when i power up so at least i know the equipment wont run it interference with household appliances. As for the sound i feel my music is now clearer and tighter, and im sure the PS audio tweaks has contributed to it. I attribute being enlightened about the importance of feeding your system nice clean power to DK. Next up some of those new PS audio perfectwave cables for the PPP and MP4k
  • lightman1
    edited May 2009
    Nothing like good clean power there, subie.
    Nice to hear the diff, isn't it?
  • superjunior
    edited May 2009
    lightman1 wrote: »
    yes my freinds, cold ones are on me :) at some point I'm gonna have to get an electrician over here. Thanks for the advice fellas
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    Toolfan66 Posts: 18,035
    edited May 2009
    I have a monster power conditioner as well, and i plugged the XP-3 in it. what happened here is at higher volumes the amp would start clipping. as soon as i plugged it into its own circuit the clipping stopped. Emotiva will tell you to plug it in its own circuit as well.
    Enjoy!!
    Larry.
  • superjunior
    edited May 2009
    Enjoy!!
    Larry.
    thanks for the heads up, Larry
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • rtart
    rtart Posts: 848
    edited May 2009
    The heater is the real power hog. I'd run a dedicated circuit, 20 Amps (12AWG) preferably.
    Also, a device that uses a LOT more power than people think is a Laser printer. When the heater inside the fuser element kicks in, the current draw goes through the roof.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2009
    Heater should be on its own circuit, definitely.
    In fact you should have at least 2-3 dedicated circuits, if you have big amps in your rig. One for each amp and the last for the TV/projector.
    Best is if you have the entire HT on a subpanel :)
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
    edited May 2009
    appadv wrote: »
    Thanks, all i need is more ideas to spend more money.:p
    Good thing i have a good friend that is an electrician. He just put in another subpanel in my garage for my welder and airconditioner 2 weeks ago.
    Right now i have my conditioner plugged in one outlet and the amp plugged into another outlet.
  • superjunior
    edited May 2009
    appadv wrote: »
    getting estimates on a new subpanal this week, not going to be easy in a finished basement with finished walls,ceiling,ect.. man this is getting expensive! Thank you folks for the good advice
    jr
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
