SDA SRS purchase
2
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    can anyone name this connection? Sorry Ben, I lost you trying to send you this pic.
    I understand the distaste for Sony but the specs on this amp are not bad...
    Currently there is a Sony TA N80ES Power Amp for sale on AUDIOGON for less than $500 and here are some of the amazing specs of this vintage Sony Power Amp that has a variable attentuated input option which can eliminate the need to use a Preamp for the Audio Purist and it can be run in Stereo or bridged into a very powerful Monoblock-
    2x 270W (4Ohm, 20Hz...20kHz, THD 0,006%)
    2x 230W (6Ohm, 20Hz...20kHz, THD0,005%)
    2x 200W (8Ohm, 20Hz...20kHz, THD 0,004%)
    1x 610W (8Ohm, mono,20Hz...20kHz, THD 0,004%)
    So if you're looking for a Power Amp that can deliver real world high wattage thruought the entire Audio Spectrum and not just test well on the bench at 1k hz like so many modern Receivers are spec'd then the TA N80ES may be just what you need.
    I like to listen, tinker, listen and repeat.
  • pablo_rodz
    pablo_rodz Posts: 331
    edited May 2009
    Wow!!! what an upgrade!!!! Congrats!! I hope to listen to some of those at least once before I die...
    HT:
    Projector - JVC HD100, 100" Fixed Screen, A/V Receiver - Pioneer Elite VSX-92TXH, Power Conditioner - Panamax M5300-EX, BluRay - Sony PS3, (2) ADCOM GFA 555 Bridged, Speakers - LSi 15, LSi C, LSi FX, Sub - 12" M&K VX-1250.
    Living Room:
    Schiit Saga, Parasound HCA-600, OPPO BDP-103D, LSi7
    nooshinjohn Posts: 25,931
    edited May 2009
    I am willing to come down and assist in any way I can helping you set them up properly. I am just an hour north and need an excuse to get out of the house... PM me if you like
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    I cant PM. I only have 8 posts. Sure I would love for you to come down. I've been talking with Ben and he is helping me spec out some of the right stuff so I can get away from my "Ghetto" Setup. Let me pick up a HK AVR and maybe an adcom amp and get the furniture in here this weekend and you can come over anytime!
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    I'm posting this one so I have 10 posts so I can PM...
  • pablo_rodz
    edited May 2009
    Bigbang wrote: »
    Let me help you....
    Where are you located?
    HT:
    Living Room:
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    The Heartland. Indianapolis, Indiana...
    heiney9 Posts: 25,445
    edited May 2009
    You might consider this one .... It is a touch light on the watts but it is a very under-rated amp.
    http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1245393418&/Nakamichi-Stasis-PA-5-threshol
    That is a very nice amp and it will make the SDA's sing, Not too light for the SDA's.
    edited May 2009
    Bigbang wrote: »
    Those specs aren't great at all. Only 70 extra watts of output from 8 down to 4 ohms? A good amp will come close to doubling it's output from 8 to 4 ohms so it should be 200wpc @ 8 ohms and 400wpc at 4 ohms. Some middle of the road amps will do 50% or more.
    Get yourself a serious amp if you want to really use the SRS's as intended.
    Those specs are pretty bad.
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    Thanks Heiney9. I'll take your advice. I was thinking an Adcom with a HK AVR reciever with pre outs. Do you have a suggestion?
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    Go to bed:p
    Ben
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    Hey, Ben... What are you doing up. I was checking out the Nelson Pass DIY Amps...
    http://www.passdiy.com/gallery.htm
    I can't help it, I'm hooked.
    David
  • ben62670
    edited May 2009
    By a used amp for now. You have a long road ahead with mods and such before a real nice amp will do you justice.
    Ben
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    I'm usually to impatient to start slow but your right... I'll look for a nicer HT reciever and a little better amp. Thanks for all your help. I'm sure I'll have more dumb questions along the way. I love these speakers!
    Thanks again,
    David
  • erniejade
    erniejade Posts: 6,321
    edited May 2009
    ben62670 wrote: »
    That figure is from the side wall;)
    Ben
    YEP from the side wall. I was reading on here somewhere that people were sayging from the back of the wall I was like NOPE!!
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    Guys,
    I took a very good listen today to the tweeters on the SRS's and found that I really have one good one on the right channel with three barely putting out audio and two good on the left channel with the other two barely putting out audio. Is part of this the SDA? I thought the SDA only affected the drivers and not the tweeters? Or is it a combination of both blown tweeters and the SDA?
    Thanks again in advance,
    David
  • ben62670
    edited May 2009
    That is normal;)
    Ben
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2009
    Bigbang wrote: »
    Guys,
    David
    Sounds like you bought a defective pair of SDA's. I'll take them crappy speakers off you hands free of charge.
    :p
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    Leroy,
    You just might have to. I might be too dumb to own them... Even with the "defective" tweeters and my "ghetto" setup (reciever/headphonejack/pre-amp) connected to a crappy Sony T N80ES... They sound f-ing great! I can't wait to see what they will do with a real setup.
    So... If I may ask. How would I test the tweeters to see if they are functioning?
    Why do some of the tweeters put out more sound than the others in the same cabinet?
    David
  • ben62670
    edited May 2009
    The tweeters are a tapered array. One of the tweets will put out most of the sound. The others will assist with a little reinforcement. I prefer a single tweeter in my builds, but this puts a lot of stress on them. I have a big pile of burnt tweeters to prove this.
    Ben
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    AHHHH. Thanks again Ben. More dumb questions to follow. Thanks for helping!
    edited May 2009
    Bigbang wrote: »
    Guys,
    David
    Yes, it's part of the design and is referred to as a "progressive point source". The Sda comes from the outer drivers in the array and does NOT include the tweeters in the stereo dimensional array.
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    Thanks H9. I purchased some material to recover the grills and the sides (Thanks DK) and I was wondering what success other people have had with attaching the fabric. I repaired some sections with hot glue and I like the fact that it dries quick but should I be using something else?
    edited May 2009
    Bigbang wrote: »
    Leroy,
    David
    I am willing to take them off you're hands as well. I will even trade with you. I have SDA-1c's that are fairly well sorted out and sound fantastic...
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    Thanks for the offer but I'm in love with these and I like to start new projects I know nothing about.
    D
    Toolfan66 Posts: 18,069
    edited May 2009
    :eek: He would still need a better setup.:p
    edited May 2009
    Bigbang wrote: »
    D
    Your at the right place for help, The guys here have givin me plenty of help.
    Spending money that is!!!;)
    Don't now what your budget is but i would guess a $1000 would get you started in the right direction in the used market.
    Larry.
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    I have to integrate it with my HT so I was talking to Ben and he suggested an Adcom amp and maybe an HK AVR with the pre outs. I've been looking at those and hoping to stumble across something on cl in the meanwhile. My wife did just get used to the shock that I was actually keeping these so I'm laying low for a few days... :)
    noosh, I like those 1c's but these SRS's need some tweaks and I need to learn. Hey, When are you coming down? I need all the help I can get.
    David
  • Lord Vader
    Lord Vader Posts: 167
    edited May 2009
  • Bigbang
    Bigbang Posts: 233
    edited May 2009
    I've been playing with the placement of the SRS's as suggested by Ben. Specifically working on the 3 feet on the left. Moving everything to the right I can squeeze about 2' 4" out of the left with the placement of about 5' 8" apart from inside to inside, 6" out from the wall.
    This seems to be the best listening configuration but once the furniture arrives it will cause everything to look too far to the right. When I move the left speaker closer to the wall (about a foot away) it lessens the SDA effect but gives me a better, tighter bass.
    I was thinking about getting a new smaller cabinet to store my components. I'll still need to shift everything back to the left a little but I was thinking a smaller cabinet would help. What do you guys think?
    Pic attached
    Thanks,
    David
