Breaking an amp in or problems with my Emotiva LPA-1
fatchowmein
I should be asking at the Emotiva Lounge but I'm just too lazy to create another username and password so I'll ask here.
Just off the top of my head, I'm guessing my LPA-1 (225W@ 4ohms) is around 18 months old. Initially, I thought it drove my LSi's well (15's, C, 9's) but lately I'm cranking the volume higher and higher (about 15-20db hotter). Seems like it lost a bit of oomph. Is this just simply a matter of an amp that has mellowed out after a prolong breakin period or maybe it's just my ears (more critical or loss of hearing :rolleyes: ) or both?
Anyone else have similar experiences with their amps? I'm merely curious. Too tide up at the moment to go buy a replacement (those Rotels in the FM were pretty nice though).
Post edited by fatchowmein on
Okay. So my eyes are going too. Would someone move this post over to Electronics?
Thx! -
Now you know why I always recommend 200wpc @ 8ohms. The higher you go in volume is the more you demand from the amp. It's running out of steam due to the load it's trying to push.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Check all of your connections. Just a thought.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Are you saying the amp has used up its electrons.
If it has not broken it should be generating the same power it had 18 months ago.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
It is generating the same power, however, it has to work much harder the louder the volume goes. The same thing happens to receivers. If he had one it would be going into protect mode & shutting down.
He said it himself, he's been pushing up the volume creating more demand for the amp.
As it is I bet he could fry an egg on top of the LPA when it's pushed hard.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Oh yes. I misread the original post. I was thinking he was saying that it is not as loud now as it was 18 months ago.
He might have crossed the audio event horizon and the sound is being sucked into an audio black hole. Thus it would not sound as loud.Lumin X1 file player, Westminster Labs interconnect cable
I get 115 db easy and often in a large room from my lpa,it never get's more than barely warm,it's also never run out of power.I do have it hooked to some pretty eff. speakers. -
I think you are literally breaking the amp with cranking up too much. The EMO might not have the magic to stand up against the demanding load such as LSi speakers.
Or like you said, there is something really started to get wrong inside the amp. Call Emotiva before it become a paperweight.
Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Nuts, I wasn't clear.
The amp is barely warm and responds the louder I crank the volume without getting hot. My current perception, however, is that I'm having to turn the volume up to achieve the same loudness that I was used to 18 months earlier.
Could be just the air between my ears. -
Check the Flux Capacitor!
Pioneer Elite Kuro 50" Pro111FD
Front: Polk LSi15
Center: Polk LSiC
Surround: Polk LSiF/X
Sub: Polk PSW10
Amps: Rotel RB 993 &
Parasound HCA-800 II
Pre/Pro:Anthem AVM-20 -
LOL! Maybe it's time you saw an ear doctor!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Kex,
That 4chanman dude is a sucker! He has scripts in other of his posts. I am going to report him to the mod.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
First, a rash of trolls, now this, and veteran members asking for their accounts to be deleted?
What next?!
Yeah! It's been a little abnormal in the CP lately. I hope things will get back to normal. It must be due to the change in the weather.
It's sunny 82 degrees here in the High Desert. How's the sky in LA?Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
fatchowmein wrote: »The amp is barely warm and responds the louder I crank the volume without getting hot. My current perception, however, is that I'm having to turn the volume up to achieve the same loudness that I was used to 18 months earlier.
What have you changed recently in your system??
I've even had ICs that required more volume.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Blu-ray player and HTPC in the past 18 months. I'll tear down the A/V rack, dust/clean, and reassemble it this weekend. -
LSi series love power.....when i run LSi15 in stereo mode, it's sounds better with XPA-5 compared to running 5 speakers with XPA-5....try to run in 2 channel mode and see if there's any difference....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
Something must have been loose. I unplugged everything, dusted, cleaned, reconnected, and recalibrated. It's all okay for now.
