need new sub?
hdoggie24
Hello, I definitely need a new sub. I have had a sony sawm-40 for a very long time now. Moved into bigger house and this sub just doesn't rumble me at all. Im looking for the best sub I can find for $250-275 or less. I mainly use for home theater but occasional music. what do you all think. thanks
Post edited by hdoggie24 on
I would say most people will tell you the polk psw505 is your best bet. It might be a little more then you range but it seems like a good banf]g for the buck sub.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
What are your room dimensions? That'll have a lot to do with the size sub you need.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
For what its worth, im running 2 psw10's in a room that is 25x15. they rumble enough for me although it did take me numerous times moving them around the room to get the best sound. Good luck.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
That's a tough price range but the already mentioned psw505 and the BIC Acoustech H100 are two of the better ones for small to medium sized rooms for the money. They may be all you need, but you may be better off saving up about $400-$600 and should be able to find something that you will not feel the need to improve on for a while.
Below link looks like a good price on the H100, just not familiar with the retailer.
H100 $249 -
thanks all. my room by the way is 20x15 so what now? so what do people think is better. psw505 or the bic h100. heard good things about the bic but should i keep my whole line polk or not.
Tough call. Assuming that room has 8' ceilings both should do an adequate job (depending on your expectations), but I would not recommend anything with less performance, and as usual a better sub would yield better results. They are pretty equal IMHO, although the 505 is shielded and the Bic is not if you still have a CRT display and plan on placing the sub near by. If not then it is not of much importance.
With a sub there is not a need to keep it the same brand as the rest of your speakers, but I guess there is a little cosmetic appeal to seeing the Polk badge on all your speakers if that is important to you. Speaking of looks I think the 505 is a little easier on the eyes, if you end up placing it in a highly visible location. IMHO these two are so close that I would go with which ever one I could find the cheapest and get the soonest. Don't forget shipping while neither is a brute, weight wise 50-55 lbs shipping adds some cost. Polk CS should also be considered although I have never seen anything on either sub that would indicate any type of a high failure rate. Or...... take some time to look for a better sub on the used market. -
My ceiling has 9' ceilings. Looks aren't a huge deal to me. Any sub i get will look fine in my room. I just want a sub to work excellent for movies for the lowest price right now.
You are pushing 3000 cubic ft assuming you have some opening to other rooms, IMHO you will not get "excellent" results for movies for $275. While the 505 and BIC give good results for their price range I can not recommend them for someone with high expectations.
Here are some links to keep an eye on:
SVS B-stock
Audiogon
HSU clearance
Polk FM -
Did not know that SVS and HSU had clearance items. Thanks for the tip apphdSony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
Atmos: Polk OWM3 x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables -
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D
