I need help w/ my Pio. BD 51, PLEASE!
polkapolka
polkapolka Posts: 145
edited May 2009 in Electronics
Hi guys, well here I am asking for your help and expertise yet again.
The problem: BD turns off each time I press play.
1.) Hooked up to Elite VSX 03 (in sig.).
a.) The amp also turns off, maybe that is the prob?
2.) Started happening after using new Logitech 820 remote.
a.) Reset all settings, no help.
3.) Also happens with all 3 remotes; original BD, original amp, and the new Logitech.
a.) When I press "play", the BD player shuts off, along with the amp. Sometimes the BD player will power up again, and sometimes not.
b.) When using the original BD remote, the exact same thing happens.
Is there a way to reset the BD player?
Have tried everything I know. I have looked at some of the FAQs for these items, but nothing beats real help from you guys. So, please don't refer me back.
I am just baffled by this.
Thanks for your help guys,
Matt :)
Mitsubishi 60" HD LDP
Polk RTI-A3 L/R
Csi-a4 CC
Polk CSW 10 Sub
Pio. Elite VSX-03
Pioneer BDP-51FD Blu-Ray
Polk Fxi3s for surround.[/SIZE]
Post edited by polkapolka on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2009
    Have you tried calling Pioneer?
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2009
    HDMI control setting? Check Harmony Remote Settings.
  • Solumnus
    Solumnus Posts: 48
    edited May 2009
    I would almost guarantee it is the Harmony remote. I have never had any luck with those things. But try to use the system (BD 51) with the supplied remotes and see what happens. If there are still problems it may be a faulty remote or player. If it works, it is probably the Harmony.
    Wait, lol, I see you have tried the original remotes. I think there is something wrong with the player if no remote works at all. Or maybe the Harmony did something to the infrared signal in the player and it "thinks" it is doing something else. Sorry I couldn't be more help, but I think you will have to talk to Pioneer on this one.
    Toshiba 62HMX85
    Panasonic DMP-BD60
    Xbox 360 with HD-DVD
    Pioneer VSX-9130-TXH-K
    Polk Audio CSiA6
    Polk Audio RTi10's
    Polk Audio RTi4's
    Polk Audio RTi6's
    Polk Audio PSW505
  • danger boy
    danger boy Posts: 15,722
    edited May 2009
    leroyjr1 wrote: »
    :p:p:p
    PolkFest 2012, who's going>?
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited May 2009
    Factory Reset:
    1. Turn it on.
    2. Make sure there is no disc loaded.
    3. Press and hold "stop", press STANDBY/ON.
    I would also make sure the "HDMI Control" is set to off in setup menu.
  • polkapolka
    edited May 2009
    leroyjr1 wrote: »
    That's my next move. But, I wanted to get opinions to see if it was actually Pio., or maybe the remote.
    Good call, thanks, Matt
    Sherardp wrote: »
    Ahh, yes! I just read the last post, and now see that you were both on target. I have to turn the HDMI control to "off" for this bad boy.
    I will post follow up when I get a chance.
    Thanks, Matt
    Solumnus wrote: »
    Yeah, this is confusing, but I think that the HDMI control should be turned to "off" as I just read through the helpful responses here, which suggest to do just that.
    I do think this stinkin' harmony remote is schizophrenic though, lol! :) It does some crazy stuff.
    Thanks, Matt
    WilliamM2 wrote: »
    Factory Reset:
    1. Turn it on.
    Thanks so much! I was just reading your post, and :eek:, a light bulb went on. I was so confused, because that doesn't happen very often with me, lol. You and sherardp hit the nail on the head with the HDMI "control" issue.
    I will also try to reset the factory reset.
    I appreciate your help.
    Thanks again,
    Matt
    Polk RTI-A3 L/R
    Csi-a4 CC
    Polk CSW 10 Sub
    Pio. Elite VSX-03
