Does listening in Ultra linear mode make you a snob?
Ern Dog
Ern Dog Posts: 2,237
edited May 2009 in 2 Channel Audio
I had some friends over to listen to my rig last night and one of the guys called me a snob just because I like to listen to my tube amp in Ultralinear mode instead of pure Triode mode. That was a first for me. :p
Post edited by Ern Dog on
    nooshinjohn Posts: 25,977
    edited May 2009
    You have Ultra Linear mode? I am sorry but thats downright snobbish in my book, and then you rub your friends noses in it like that? Does arrogance know no bounds these days?:p;)
    j/k... I like my sound as pure as i can get it too. They were just jealous they cannot appreciate the same in their own homes...:)
  • mantis
    mantis Posts: 17,557
    edited May 2009
    Ern Dog wrote: »
    Thats the stupidest thing I have ever heard. Listen how you like Bro, Snob or not.
    Dan
    Dan
    mhardy6647 Posts: 35,194
    edited May 2009
    Ultra-Linear would be, in most snob hifi circles, the equivalent of marryin' your cousin, havin' a rusty pickup on concrete blocks in the front yard, and some houn' dogs bayin' on the porch of the double-wide.
    Single-ended Class A no NFB and a power supply that could choke a rhinoceros -- for 1 watt per channel, or less. Now you're talkin' snob...
    http://www.the-planet.org/nnetg.html
    Not snobs... nope, not us...
  • [Deleted User]
    [Deleted User] Posts: 1,394
    edited May 2009
    I have no idea what this ultra linear triode pentode modular mode is. Is this audiophile vocab? I am not there, what the hell is this?
    Seriously,
    Halen
  • beardog03
    beardog03 Posts: 5,550
    edited May 2009
    Yep !
    To all of the above....
    I also found that it depends on what type of music you are listening to, and what tubes you are running, and alot of other variables.....
    I usually listened to my V12 in UL mode
    Speaks make a big difference also....
    if you are into silky sweet mids, Triode is they wat to go,
    UL seems to give much more across the range output power
    IMO
    at least the `ol V12 seems that way
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Face
    Face Posts: 14,340
    edited May 2009
    halenhoang wrote: »
    Seriously,
    Halen
    Tube amp topologies.
    I only listen to my Stingray in triode mode. It would be nice to have a little more headroom though, but a 80+wpc triode amp would break the bank at the moment.
    edited May 2009
    halenhoang wrote: »
    Seriously,
    Halen
    Triode mode means wiring a pentode or a "beam power" output tube to operate in the same manner as a triode. This is intrinsically more linear but less efficient (i.e., less output power) than exploiting the extra grids (screen and suppressor grids) in a pentode. Here's a relevant thread:
    https://www.polkaudio.com/forums/showthread.php?p=832643
    also: http://www.webace.com.au/~electron/tubes/triode.htm
    Ultralinear mode is a particular application of feedback from a tap on the output transformer back to the power pentode to flatten frequency response and reduce distortion (THD) at any given power level. I b'lieve it was invented by David "Dynaco" Hafler (certainly looks like it).
    http://www.webace.com.au/~electron/tubes/ul.html
    You might also want to look at pp 20-27 of http://www.anthemav.com/oldsitev1/pdf/taste.pdf
  • madmax
    madmax Posts: 12,434
    edited May 2009
    That is the real snob teritory. Where do I get one? :)
    Vinyl, the final frontier...
    edited May 2009
    best bet: build your own...
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2009
    Whichever one you listen to means you're a freakin geek!
    edited May 2009
    cfrizz wrote: »
    guilty as charged.
  • organ
    organ Posts: 4,969
    edited May 2009
    Hey man, maybe your friend is jealous of your set up. Snob? No way. Snobs are usually into triodes. The lower the power output, the more snobby lol:D.
  • cfrizz
    edited May 2009
    :D LOL guilty & proud of it! March on with your geeky self!:D
    guilty as charged.
  • Ern Dog
    edited May 2009
    organ wrote: »
    Too Funny! :D
  • doctor r
    doctor r Posts: 837
    edited May 2009
    I really can't beleive that you would even own an amp with the, dare I say it, triode option switch. Just having that switch in the same room makes it possible for you to do the unthikable and ... I hate to consider the possibilities, the lose of stature, the possible expulsion from the Country Club. Quickly have it modified so you are not tempted. Triode mode has ruined so many who's futures were bright.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
