Does listening in Ultra linear mode make you a snob?
Ern Dog
I had some friends over to listen to my rig last night and one of the guys called me a snob just because I like to listen to my tube amp in Ultralinear mode instead of pure Triode mode. That was a first for me.
Post edited by Ern Dog on
You have Ultra Linear mode? I am sorry but thats downright snobbish in my book, and then you rub your friends noses in it like that? Does arrogance know no bounds these days?:p;)
j/k... I like my sound as pure as i can get it too. They were just jealous they cannot appreciate the same in their own homes...:)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thats the stupidest thing I have ever heard. Listen how you like Bro, Snob or not.
DanDan
Ultra-Linear would be, in most snob hifi circles, the equivalent of marryin' your cousin, havin' a rusty pickup on concrete blocks in the front yard, and some houn' dogs bayin' on the porch of the double-wide.
Single-ended Class A no NFB and a power supply that could choke a rhinoceros -- for 1 watt per channel, or less. Now you're talkin' snob...
http://www.the-planet.org/nnetg.html
Not snobs... nope, not us... -
I have no idea what this ultra linear triode pentode modular mode is. Is this audiophile vocab? I am not there, what the hell is this?
Seriously,
Halen -
mhardy6647 wrote: »Ultra-Linear would be, in most snob hifi circles, the equivalent of marryin' your cousin, havin' a rusty pickup on concrete blocks in the front yard, and some houn' dogs bayin' on the porch of the double-wide.
Yep !
To all of the above....
I also found that it depends on what type of music you are listening to, and what tubes you are running, and alot of other variables.....
I usually listened to my V12 in UL mode
Speaks make a big difference also....
if you are into silky sweet mids, Triode is they wat to go,
UL seems to give much more across the range output power
IMO
at least the `ol V12 seems that wayCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Tube amp topologies.halenhoang wrote: »I have no idea what this ultra linear triode pentode modular mode is. Is this audiophile vocab? I am not there, what the hell is this?
Seriously,
Halen
I only listen to my Stingray in triode mode. It would be nice to have a little more headroom though, but a 80+wpc triode amp would break the bank at the moment."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Seriously,
Halen
Triode mode means wiring a pentode or a "beam power" output tube to operate in the same manner as a triode. This is intrinsically more linear but less efficient (i.e., less output power) than exploiting the extra grids (screen and suppressor grids) in a pentode. Here's a relevant thread:
https://www.polkaudio.com/forums/showthread.php?p=832643
also: http://www.webace.com.au/~electron/tubes/triode.htm
Ultralinear mode is a particular application of feedback from a tap on the output transformer back to the power pentode to flatten frequency response and reduce distortion (THD) at any given power level. I b'lieve it was invented by David "Dynaco" Hafler (certainly looks like it).
http://www.webace.com.au/~electron/tubes/ul.html
You might also want to look at pp 20-27 of http://www.anthemav.com/oldsitev1/pdf/taste.pdf -
mhardy6647 wrote: »Single-ended Class A no NFB and a power supply that could choke a rhinoceros -- for 1 watt per channel, or less. Now you're talkin' snob...
That is the real snob teritory. Where do I get one?
Vinyl, the final frontier...
best bet: build your own...
Whichever one you listen to means you're a freakin geek!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Hey man, maybe your friend is jealous of your set up. Snob? No way. Snobs are usually into triodes. The lower the power output, the more snobby lol:D.
Too Funny!
I really can't beleive that you would even own an amp with the, dare I say it, triode option switch. Just having that switch in the same room makes it possible for you to do the unthikable and ... I hate to consider the possibilities, the lose of stature, the possible expulsion from the Country Club. Quickly have it modified so you are not tempted. Triode mode has ruined so many who's futures were bright.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter
