MIT Cables - What we really get! :-D
  • Face
    Face Posts: 14,340
    edited May 2009
    alphaone wrote: »
    I was told by a local high end dealer that the cheaper the speakers the greter the notice of improvement.
    That's backwards.
  • Ricardo
    Ricardo Posts: 10,636
    edited May 2009
    alphaone wrote: »
    He he he......
    SOPA
    treitz3 Posts: 19,989
    edited May 2009
    Alphaone, you have much to learn. You have also been absorbing the wrong information, as well as been given bad advice.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2009
    I don't know. I think formula one tires on a chevette makes perfect sense.
    Ben
    F1nut Posts: 51,760
    edited May 2009
    alphaone wrote: »
    Honkyo 805, LSi15. Before, RM30 speakers. I also had a Pioneer 1028 with the RM30.
    I was told by a local high end dealer that the cheaper the speakers the greter the notice of improvement. I anso tried the RM20s. I couldn't notice any imptovement.
    He was pulling your leg. I mean, if that was true we'd all be using Walmart speakers.
  • alphaone
    alphaone Posts: 26
    edited May 2009
    Or he wanted to sell the wires.
    nooshinjohn Posts: 25,916
    edited May 2009
    ben62670 wrote: »
    I agree on that... f-1 tires and then some...
  • alphaone
    alphaone Posts: 26
    edited May 2009
    I am getting my XPA-5 on Monday. I hope it impresses me more that the Terminators 4 driving the 4 LSi15, the LSiC and the RM 30 (these to be replced by the LSi9s). It's going to be a long weekend wayting. I want to try some SACDs and movies.
    F1nut Posts: 51,760
    edited May 2009
    Ummm......Terminator 4 cables don't drive anything, they mearly carry the signal. Of course, since you sold the MIT's in haste, you're not going to know how they might have sounded with a separate amp.
  • engtaz
    engtaz Posts: 7,669
    edited May 2009
    Welcome Gavin. Great to have you here.
    engtaz
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited May 2009
    You have to have good gear to have good cables make a difference; you have to have primo gear to have primo cables make a difference. It really boils down to that.
    In my system, the 10-gauge OFC stranded wire is actually overkill but it does the job and looks cool, snaking across the floor. I could elevate it off the carpet using styrofoam cups, but .... :o
    .... it's all good ! :)
  • alphaone
    alphaone Posts: 26
    edited May 2009
    Sorry, my first language is not English, I wanted to say the XPA-5 driving those speakers.
    The 10 gauge 588 strands KnuKonceptz speaker wire should do a good job.
    tonyb Posts: 33,072
    edited May 2009
    alphaone wrote: »
    You were told wrong.Obviously to sell you something.
  • CoolJazz
    CoolJazz Posts: 572
    edited May 2009
    Actually, the Audioquest demo of a few years ago showed that it didn't take anything close to high end gear to hear a difference in speaker cables. Some of the cable doubters around here should have heard this demo. You went away with no doubt whatsoever as to cables having an impact. None...
    They took a simple boombox, picked up on the way to the Stereophile Show, for about $50. It was a CD player one with detachable speakers. They broke the cheesy cable that comes with it, didn't remove it, and just added into the middle banana plugs. This made it so that during the demo they could switch in different cables while playing a CD music cut from the boombox. Note...not a single high end component, not a single mod to the boombox outside of enabling the ability to add cables.
    The setup was just a row a chairs down the opposite wall, so most didn't have a sweetspot position. At that point, seeing the setup and the equipment, it was hard to imagine how we could hear any kind of change in cables. I was unconvinced at the time that cables could really make much of any difference beyond maybe the guage impacting a little.
    As they switched between cables, it became obvious to everybody in there, that it wasn't hard at all, even on this grade of equipment to hear the cables impact the sound!! They didn't seem to work hard at selling or focusing on prices, just there to make the point that cables DO MAKE A DIFFERENCE!
    Here is a link to a story of the demo in a version some 10 years or more after the one I saw, so you can get it in someone else's words...
    http://www.avguide.com/blog/the-audioquest-boombox-demo
    CoolJazz
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • alphaone
    alphaone Posts: 26
    edited May 2009
    I just want to give an idea of how I decided to go with kind-of-regular speaker wire. I just looked for basic side-by-side wire, thick enough for any amount of current, oxygen free copper so it would have less impurities, with high strand count because current tends to flow in the wire’s surface.
    My decision was based on the information I found on the links below, among other. I couldn’t find some more technical sites I saw before. I will post them when I find them.
    I looked everywhere for information in sites and books, forums, remembering what I learned from my EE degree, etc. There are opinions on the matter all over the place which often create confusion more than inform. It’s almost like a religion, you must have faith. So I tried to look for facts. I also understand that theory and reality may be different.
    I believe that there are differences for the better in expensive cables, just not enough to justify the cost. For example, it seems that some cables try to get all frequencies to the speakers all at the same time because highs travel faster than lows, but who can notice a difference of a nanosecond in time?
    I am just trying to clarify my doubts, not to alienate or contradict anyone. Maybe it will stimulate the conversation so others may add to it so we can learn more from the post of their experience and knowledge. May be I will get different cables in the near future.
    Here are some links
    Cable Budget Guidelines:
    http://www.audioholics.com/buying-guides/how-to-shop/cable-budget-guidelines
    Audio Cables - Fact & Fiction Revealed:
    http://forum.ecoustics.com/bbs/messages/5/6528.html
    Top Ten Signs an Audio Cable Vendor is Selling You Snake Oil:
    http://www.audioholics.com/education/cables/top-ten-signs-an-audio-cable-vendor-is-selling-you-snake-oil
    From High Det Forum; Truth about speaker wire:
    http://www.highdefforum.com/speakers-surround-sound/48921-truth-about-speaker-wires.html
    edited May 2009
    Please do not believe everything you read on the internet. Your ears will thank you. See if, in the meantime you can borrow a set of DBS cables from somebody to use in your own rig. It might just make you smile from what you hear.
    F1nut Posts: 51,760
    edited May 2009
    alphaone wrote: »
    For the level that you're at, I'm sure they will. For the level that others are at, they will not.
  • wizzy
    wizzy Posts: 867
    edited May 2009
    CoolJazz wrote: »
    Actually, the Audioquest demo of a few years ago showed that it didn't take anything ...
    Comments removed after re-reading that post :)
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited May 2009
    I have ran a few differant types of wire and i'd say they all sounded the same pretty much, until i then tried em running thrumy amps and then big differance in each wire.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • gavn8r
    gavn8r Posts: 53
    edited May 2009
    heiney9 Posts: 25,432
    edited May 2009
    gavn8r wrote: »
    Thanks. This is a lively group!
    That's a good way of putting it. I'd say some of us core members are a bit passionate about things we believe in and audio in general. :).
    Perhaps you can help me out.............maybe this is the right venue maybe not. I'm looking for a pair of 8' NOS or used Terminator 2's with Iconn's.
    Perhaps you could PM or e-mail me if you have any ideas where to find a pair or perhaps you have access to some.
    TIA
  • engtaz
    engtaz Posts: 7,669
    edited May 2009
    Cables are always lively. :)
    engtaz
  • Matt34
    Matt34 Posts: 318
    edited May 2009
    WilliamM2 wrote: »
    Here is an interconnect, all that crap in the signal path had to be good. Yop quality swtches as well.:rolleyes:
    This is what I don't understand, some here are absolutely against having an EQ/ tone control in their system saying it's another link in the chain and that if your system needs EQ you need better equipment.
    .....but they will buy extravagant cables to alter the sound and signal path.
    alphaone,
    It isn't much of a mystery what speaker wire is suppose to do, if a perfect wire were possible, it would have no resistance, no capacitance, and no inductance. The shorter a wire is, the closer it comes to being perfect.
    There are many other factors that I would focus on in getting your system (and room) to sound right first. Once you have them dialed in, then worry about the two electrical conductors individually insulated by plastic.
    Good luck!
  • Face
    Face Posts: 14,340
    edited May 2009
    Why, because it's not an EQ. It removes noise and corrects impedance mismatches.
    edited May 2009
    Matt34 wrote: »
    That's answered very easily. It depends on where the individual is on thier own personal audio journey. Sometimes each is a benefit and at the same time each can be a detriment.
    Oh, and what Face said.
    F1nut Posts: 51,760
    edited May 2009
    Face wrote: »
    Ding Ding Ding! We have a winner.
  • dkg999
    dkg999 Posts: 5,647
    edited May 2009
    alphaone - I have a roll of the blue wire you reference, and while it's not bad in comparison to what else there is in it's price range, if you can't hear a difference between it and the MIT cables, then you probably shouldn't really worry about what cables or components you use, and just enjoy the music.
    DKG999
