Wired? Why my PS3 cannot output Dolby TrueHD to my Denon Receiver through HDMI
woweu2006
woweu2006 Posts: 68
Wired? Why my PS3 cannot output Dolby TrueHD to my Denon Receiver through HDMI?
I just hooked up my PS3 ( 80GB ) to my new Denon AVR-989 receiver. And realized that there is no Dobly TrueHD signal to my Denon receiver. I checked PS3 set up, and there is no Dobly TrueHD output option through the HDMI port.
Anyone know this issue?
thanks
Sony BRAVIA W-Series KDL-52W4100
Polk Audio LSI15 - Front
Polk Audio LSIC - Center
Polk Audio PSW10 - Sub
Polk Audio R50 - Surround
Playstation 3 80GB - Blu-Ray Player
Denon AVR-989
Denon 758
http://californiammo.com/
:D:D:D:D:D:D:D:D
Post edited by woweu2006 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2009
    The receiver needs to have 1.3 HDMI input to do that.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    yes, my receiver has 1.3 HDMI. It's a Denon AVR-989.
    Looks like PS3 cannot output Dolby TrueHD signal to the receiver via HDMI 1.3 cable.
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
  • cheddar
    cheddar Posts: 2,390
    edited April 2009
    You only need hdmi 1.1 to get TrueHD from the ps3 to the receiver. It internally decodes TrueHD and DTS-HD MA to multichannel PCM and sends it to the receiver in this form over hdmi. It's the same PCM that a receiver would produce if it decoded it, just saves the trouble of having the receiver do it or having everything be hdmi 1.3 for bitstreaming. But the receiver will show multichannel PCM or something like that for the input signal, not TrueHD. But the quality of the decode is the same. And the receiver can then use the PCM for all its digital processing (surround modes, etc.) just as if it had decoded the TrueHD itself.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2009
    PS3 can't bitstream the high-res formats for decoding in the receiver. Like Cheddar said, it decodes them internally then sends multichannel PCM. You're still getting high resolution sound, so you're good.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • mufsoman
    mufsoman Posts: 640
    edited April 2009
    Also be sure that you have gone through the firmware update witha new system. DTS Master Audio decoding is only available in the updates. I went through this also, as the other have said, PS3 has a physical limitation that it cannot bitstream the HD code. You have set the PS3 output to PCM.
    This is a good opportunity to ask a question to everyone.....are we missing any sound or video quality using the PS3 as a blueray for movies? Does PS3 really have good video and audio processing or are we better off with a dedicated high quality blueray player???
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
    Atmos: Polk OWM3 x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • bruss
    bruss Posts: 1,039
    edited April 2009
    mufsoman wrote: »
    I love mine and it is a great way to stream from your home pc
  • cheddar
    edited April 2009
    mufsoman wrote: »
    Not only is this question somewhat off topic from the original thread, the assumption is very misleading. There are a wide range of blu-ray dedicated players available in the market today. Some good, some not so good. And most do not offer the quality, upgradability, or support (because of sheer numbers in the market and video game hardware that is overkill for a blu-ray player) of the ps3. A better question would be to ask which new dedicated players finally match or exceed the ps3's video and audio capabilities and would the average viewer who wasn't looking at paused side-by-side video even notice...but that is a topic you should ask in another thread.
  • williamgauci
    williamgauci Posts: 88
    edited April 2009
    +1 on what Cheddar says. Other than the onboard decoding (which I love due to my older gen. receiver) I can't think of a better all around player. I've just now started getting into the music and video streaming with it. Also this year Harmony is going to be selling a remote plug in so you'll be able to use full functionality with their remotes including powering on/off. No more seperate bluetooth remote if you don't want it.
    _____________________________________________
    Yamaha 6080 Emotiva XPA-5 CSi A6 RTiA-7's RTi A1's Velodyne DLS-4000R
  • mufsoman
    mufsoman Posts: 640
    edited April 2009
    OK guys, I apologize for sending this thread off on a tangent. It was a rookie mistake. But I do appreciate the feedback......
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • cheddar
    edited April 2009
    also i think it would be better to just buy a dedicated bluray so you can have true hd because if the ps3 decodes the sound and the receiver has to unpack it again then sounds being lost instead of a cheap blue ray player is gona send it straight to the receiver where itl be proccessed without data being losed plus many blu ray players have upgrades and cool features like watching netflix and the ps3 does not but be warned i bought a magnavox blue ray player for like 110 dollers from walmart and the picture was just horrible compaired to the play station but your reciever might be able to improve on that but i say nay to the audio from the ps3
    This is completely false information. You are confusing decoding (uncompressing) TrueHD and DTS-HD MA with receiver side digital processing and eventually digital to analog conversion for your analog speakers. The decoding process to PCM is a straightforward process and you DO NOT lose any audio information when you decode a compressed TrueHD or DTS-HD MA signal. That's why they are called 'lossless' formats. TrueHD and DTS-HD MA uncompress to the SAME PCM no matter where this process takes place.
    And no matter where you decode (uncompress) the signals to PCM, your receiver/pre-amp is going to have to apply its digital processing and DAC conversion before it gets to the speakers. Some dedicated players can do an internal DAC conversion and dump it to multichannel analog outs, bypassing the need for hdmi. And this WILL be a lossy conversion, followed by another lossy analog to digital conversion if the receiver/pre still has to do some digital processing, followed by another lossy digital to analog conversion and out to the speakers. But since the ps3 doesn't have the option of multichannel analog outs and transmits digital PCM to the receiver/pre via hdmi, there is no loss of audio information until the receiver/pre starts applying its own digital processing of the PCM and its DAC conversion.
    And if you're getting horrible video from a dedicated blu-ray player, the last place you should try and improve it is with the video processing in a receiver/pre. You are much better off getting a player that can give you a pristine 1080p picture right off the blu-ray disk than relying on digital manipulation to 'correct' a bad source signal. You can't create what isn't there in the first place. You can only make the picture less annoying, not more accurate in the reproduction of the original information on the blu-ray disk.
  • bruss
    bruss Posts: 1,039
    edited April 2009
    how does the older high end recieivers stack up against this deneon 989 . and can you just pass through audio through the hdmi without messin with the picture signal. also i think it would be better to just buy a dedicated bluray so you can have true hd because if the ps3 decodes the sound and the receiver has to unpack it again then sounds being lost instead of a cheap blue ray player is gona send it straight to the receiver where itl be proccessed without data being losed plus many blu ray players have upgrades and cool features like watching netflix and the ps3 does not but be warned i bought a magnavox blue ray player for like 110 dollers from walmart and the picture was just horrible compaired to the play station but your reciever might be able to improve on that but i say nay to the audio from the ps3
    The ps3 audio is very very good IMO and there is no stand alone player that can match its upgrade capacity.
    edited April 2009
    cheddar wrote: »
    Cheddar is quite right, one of the reasons that I chose the PS3 as my Blu-ray is that my AVR has HDMI 1.1 and I didn't feel like spending another 1000 or so to upgrade. LPCM sound coming from the PS3 is converted by the DACs in my AVR which are probably better than most of the DACs available in sub 500 dollar Blu-ray players. So, I, for one, am happy.
    cnh
  • quadzilla
    quadzilla Posts: 1,543
    edited April 2009
    And another +1 for cheddar. Even though my AVR does 1.3 HDMI, I chose the PS/3 for blu-ray because it makes a damn fine blu-ray player, in addition to having a couple of other abilities ;)
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2009
    +1 on cheddar, cnh, and quad's perspective. I love my PS3 for a Blu-Ray player it does a fantastic job. It works with all the latest HD formats and the picture quality is amazing as well. Not to mention all the other stuff it does as well like quad pointed out.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • bevo
    bevo Posts: 306
    edited May 2009
    Here's what you do to get dolby true hd. Go to your video settings on the ps3. Scroll down to hdmi audio output for blue ray and switch it to linear pcm. When you put in a blue ray, wait until the movie is started. Not the title screen, wait until the feature has started, and push select on your ps3 controller. In the top right it will tell you what audio format is being used.
    I had the same problems you are having, and someone finally walked me through what you need to do. It was driving me nuts, but now I am very happy using the ps3. I just wish I could bitstream, so that I could see my receiver say, dolby true HD, or DTS-master audio, instead of multi channel in.
    Denon 1909, want to upgrade for pre outs
    Fronts-polk RTi A5
    center-polk CSi A4
    Sides Polk FXi A6
    rears- polk rm8's
    sub-SVS pb-13 ultra
    Blue ray-ps3
    Panasonic plasma 50 inch
    Buttkicker(don't use or need it anymore since getting the Ultra)
  • woweu2006
    woweu2006 Posts: 68
    edited May 2009
    imo, PS3 is really the best blu-ray player.
    my Denon avr-989's decode function is useless now, lol
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
  • danger boy
    danger boy Posts: 15,722
    edited May 2009
    how come i can't watch a blu ray movie on my PS1? :p
    PolkFest 2012, who's going>?
  • oifvet0608
    oifvet0608 Posts: 148
    edited May 2009
    woweu2006 wrote: »
    LOL, that's because you are a "special person"
    LOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOL
    Mabye since you don't know how to use the 989 you wouldn't mind just giving it to me...I've earned it.:rolleyes:
    Receiver: Marantz SR7002
    Fronts: Canton Chrono 509 DC
    Center: Canton Chrono 505 CM
    Surrounds: Canton Chrono 502 SP
    Sub: SVS PC12-NSD
    TV: 40" 1080i JVC Multisystem LCD(upgrading to 50" Samsung LED)
    Blu-Ray: PS3
    DVD: Pioneer DV-420V (HDMI)(for PAL DVD's)
    Audio/Music: MacBook Pro hooked up thru HDMI
    Gaming: PS3 (oifvet0608) XBOX 360 (JAYtheVET)
    Cables: Inakoustik Reference
  • mufsoman
    mufsoman Posts: 640
    edited May 2009
    Looks like realy started something with my off topic question on the PS3 earlier in this thread, but these comments are great. Being a newbee, I feel alot better about the PS3 decision I made after reading posts. Thanks to all......
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
