Nakamichi Bananna Plug Styles
skrol
skrol Posts: 3,448
edited October 2009 in Speakers
I did some searching about but couldn't find the answer. Forgive me it I just missed it.
I am looking at Nakamichi banana plugs and I see that there are (at least) 3 styles (Sawtooth, 7-stick, and the regular style). I can see how the Sawtooth may provide increased contact area. The 7-stick also claims increased contact area. I am wondering if these two styles universally fit most binding posts. The standard should be a no brainer.
I'll be using these with my Denon receivers and my Polk RTA11TLs and Monitor 5As. Any recommendation on which style would be best?
Stan
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
  • jacob.simpson
    jacob.simpson Posts: 481
    edited April 2009
    www.monoprice.com
    has some 2 different plugs, open screw type or closed screw type,
    both are excellent, i bought 30 pairs of the open type, excellent quality for the price, same retails for around 7 or 11 per pair in BB. The nakamichi are not from N brand, its just printed on these plugs by some Chinese manufacturers. But i have not heard any complaints till now from the users.
  • skrol
    skrol Posts: 3,448
    edited October 2009
    Thanks for the suggestion of Monoprice. I am still wondering about the different types of banana plug ends.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
    heiney9 Posts: 25,431
    edited October 2009
    Yes, the both styles fit. I used the "regular" style to make some homemade cables a while back. They are nice banana plugs only caution is they won't take anything larger than 13g wire. You can't seat the set screws with anything larger, which means the barrels won;t screw on over the protruding set screws.
    Infact any manufaturer that you look at, you should be aware of what the max size wire they will take, as there is very little way around it.
    My brother tried to use Canare Star Quad 4S11 and we couldn't seat the set screws deep enough for the barrel to screw on. Total waste, I'm not sure the seller gave that spec in the ebay posting.
  • gdb
    gdb Posts: 6,012
    edited October 2009
    I think the sawtooth style SUCKS !!
  • skrol
    skrol Posts: 3,448
    edited October 2009
    gdb wrote: »
    That is the kind of info that I am looking for. Why does it suck? Of the other 2, which would be better?
    Interestingly the description says that they will accept anything from 8 to 20 awg. Sounds like quite a range.
    Are the covers metal or plastic on the silver Nakimichi labeled plugs?
    Stan
    Main 2ch:
    HT:
    Other stuff:
    edited October 2009
    skrol wrote: »
    Yeah..............well I can tell you anything larger than 13g and you WILL have issues. This is not a guess or an assumption; it's from personal 1st hand experience. :)
    Yes, there is a small outside chance the units you are looking at have larger internal barrels................but I highly doubt it. These are general consumption mass produced parts that have hundreds of different stenciling on the barrels. I've own the exact same plugs that have the word "Digital" stenciled on them as well a set with the "N" for Nakamichi. They are identical.
    The barrels screw on and they are aluminum.
    P.s. I have no complaints, they work great for the little I spent on them. You get what you pay for. Look at the Cardas banana plugs abd you'll see why they cost so much.
  • skrol
    skrol Posts: 3,448
    edited October 2009
    I know many top quality plugs have exposed metal covers but I wonder how smart that is. It wouldn't take much to short that wonderfully crafted aircraft aluminum and fry an amp.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jimmydep
    jimmydep Posts: 1,305
    edited October 2009
    heiney9 wrote: »
    Your correct, I have the same ones and 10ga wire fits but you can't tighten the screws down enough for the aluminum barrels to fit.
    Jimmy
    edited October 2009
    skrol wrote: »
    You just have to be careful and you should never be working with IC's or speaker cables while equipment is powered up anyways. :)
  • jimmydep
    edited October 2009
    Just use a peice of shrink tube as an insulator and for strain relief.
    Jimmy
  • skrol
    skrol Posts: 3,448
    edited October 2009
    Good Idea. I was just thinking of that.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,448
    edited October 2009
    I decided to order some of all 3 styles. I'll let me know what I think. I'll let you all know also.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • lumpy
    lumpy Posts: 113
    edited October 2009
    I have the Nakamichi regular style with plastic sleeves, not aluminum. I have some of these on 12g cable but it is a flat cable and it did take some effort to get the screws to go in far enough.
    pop
    media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
    living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
  • RandyBox
    RandyBox Posts: 125
    edited October 2009
    www.monoprice.com
    Ditto! Got 10 pair (closed) in 2 days ago along with the Monoprice 12ga wire and was tickled!
    I was ticked that I cut my wire about 1 ft too short but that's another story...:o
    Randy
  • skrol
    skrol Posts: 3,448
    edited October 2009
    I got my 3 styles Nikamichi stamped bananas yesterday and they seem fairly impressively built. These include the Standard bananna, the 7-Stick and the Saw Blade.
    The first thing that I noticed, besides the weight, is that the Saw Blade is more limited in the gauge wire that it will accept. This is because the contact (blade) runs all the way through. Unless you are using thick wire, this may be a positive the speaker wire is in direct contact with the blade. The other types may have more contacts to have to make. I can't be certain without dissecting them.
    Next I tried plugging them into my RTA11TL's and Monitor 5A's. Of the three, the saw blade fit the tightest. The standard was almost as tight and the 7-stick was considerable looser. I'll try other with jacks later. This does not necessarily mean that the saw blade makes a better connection. A small imperfection in the blade or in the speaker jack can create a high friction fit but have little surface area making electrical connection. However, in the absence of such flaws, I can see where the blade potentially can make a superior electrical connection.
    I would like to do ohmic measurements of the three but I presently lack equipment with the needed sensitivity. My Fluke 187 can only measure down to 0.01 ohms. If I can borrow a 4-lead milli-ohm meter from work, maybe I'll get some results.
    Something else I noticed about the 7-stick is that it has a longer end and sticks out further than the others. Unless I am missing something, I really seen no purpose for the 7-stick type other than it looks more elegant. But who cares when it is plugged in and out of sight.
    Recommendations:
    1) Saw blade for single contact with wire and snug fit. (assumes it will accommodate wire gauge and no significant flaws in blade or jack).
    2) Standard for good all-round fit (both wire and jack)
    3) So far, I don't see any reason for the 7-stick. Potentially better contact area assuming that they stay in the jack. Maybe I'm missing something.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,448
    edited October 2009
    Ok, I found an advantage for the 7-stick. You can join them together with the saw blade to extend your speaker wire in a pinch. The standard bananas are too thick to do this.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited October 2009
    I like bananas that are soldered on. I'm looking at using the "saw" style but cryo treated and minus the "barrel" for my upcoming cable build....
    I think solderless connector's leave chance for the connection to fail over time and using a silver based, lead free solder should get rid of any extra "resistance" created by soldering and provide an excellent connection.
    Just my $0.02 :o
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • skrol
    skrol Posts: 3,448
    edited October 2009
    These do run the risk of coming loose. I suppose you could tighten the screws and solder. You would likely need a high watt solder gun as there is quite a bit of metal. The jackets are optional and I like the idea above of using heat-shrink tubing.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    edited October 2009
    FYI and FWIW, I've had a pair of screw-type banana plugs for 20+ years and the connection has never "failed" or come close to failing. Soldering is not necessary, but each person can make their own choice.
  • sTiLlLeArNiNg
    edited October 2009
    Since i have to constantly check the terminal's on my speaker's/amp every few day's to keep them tight i think i will avoid any possible headache's with the nanner's and just solder them from the get go! Plus it will seal the connection and keep it from oxidizing over time....
    If you get the proper nanner's soldering them is a breeze!
    Just my $0.02
    Media Room 7.1
    HTPC
    edited October 2009
    What type of junky ones did you have that you had to tighten them every two days. Either an extreme over exaggeration or real cheap stuff. Again I realize it's a personal preference, I perfer not to spend the extra time/money doing something I feel is totally unecessary.
    If you use high quality copper wire to begin with it takes quite awhile for it to oxidize. I've seen cheap M* copper wire start oxidizing in about 6 months...........use quality high grade copper wire and you'll minimize oxidation by 10 fold or more.
    Just my continuing 0.02C
    edited October 2009
    skrol wrote: »
    When I was using the Nak's for about a year, they never once came loose or even seemed like they could. There is no risk if you snug them down properly.
  • sTiLlLeArNiNg
    edited October 2009
    heiney9 wrote: »
    I love assumption's how 'bout you? I have mentioned a few time's since i joined the forum that i use bare wire so if you could be so kind as to send a complaint to Yamaha and Polk to tell them that they use inferior product's that would be awesome! Maybe i should try to eat some wheatties or spinach before i tighten them? :o
    Media Room 7.1
    HTPC
  • concealer404
    concealer404 Posts: 7,440
    edited October 2009
    Maybe one of the above.... I don't see how a bare wire connection would get loose by itself, personally.
  • sTiLlLeArNiNg
    edited October 2009
    Maybe i listen to my music a lil' on the loud side? I dunno :o All i know is i crank them sob's down and every few day's they work themselve's loose :confused:
    Media Room 7.1
    HTPC
  • skrol
    skrol Posts: 3,448
    edited October 2009
    I am presently using bare connections (I look forward to going 'naners) and have hot had an issue with them loosening even with relatively low dollar wire. I do loosen and re-tighten them once in a while just to scrub off any oxidation that might have developed.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    edited October 2009
    Well there's the issue, we are talking about (or atleast I am) about **** the (2) set screws (to hold the wire in place) that come with the banana plugs NOT the connectors on the back of the amp/receiver.
    Pay attention :p;):D.
  • sTiLlLeArNiNg
    edited October 2009
    I was paying attention, i was simply stating that i already have encountered issues on my AVR + speaker's (the Emotiva is fine after about a week of use) with screw type connection's so when i complete my cable build it will be with as many solder connection's as possible :)
    Might be a good idea for you to fully read a post prior to replying to it? :o
    side note: on those high dollar cable's do they use screw type connector's?
    Media Room 7.1
    HTPC
    edited October 2009
    But this thread was never talking about an AVR..............it was talking about Nak banana plugs and associated connection of the bare wire......so perhaps you should read before you reply or if you are going to shift topics make it apparent. As hard as I try I'm not a mind reader.
  • jimmydep
    edited October 2009
    I have 10ga wire into my Nakamichi (standard pin) nanners, I put them in a vise and used the 2 set screws to tighten the wire, then I ground off the excess screw so the cover would fit over the top. I put an 1-1/2" long peice of adhesive shrink tube over the top cover as an insulator and for strain relief, and I guess it could keep the copper wire from oxidizing also.
    I am constantly changing my set-up, so the nanners get alot of use. I have yet to encounter any loosening of the wire in the nanners. I think if properly done, the screw connections are 100% secure....... Just my .05c
    Jimmy
