Apc
My bad, didn't realize the receptacles for 15 and 20 amps service were not compatible. :rolleyes: Guess you better call an electrician. Although I've known many Adcom owners and none has ever mentioned a special plug or having to have a house rewired to run them.
It's always best to follow the manufacturer vs. an internet forum. Because I've never used, owned or been around Adcom products so I couldn't possibly know what I'm talking about.
Good luck
If you read the owners manual it states:
The AC cord provides power to operate all the GFA-
7805/7807’s circuits. Its plug can be connected to a
standard wall outlet provided the outlet supplies a voltage
compatible with the power requirements printed on the
rear panel of the GFA-7805/7807.
The voltage necessary is 120V....so it seems a regular wall outlet will suffice.
So it seems there is some confusion on Adcom's part as it clearly states a standard wall outlet can be used.
More info from the owners manual:
The GFA-7805 and GFA-7807 are very high power amplifiers
and as such must be directly connected to the wall outlet
or an appropriate surge protector or AC line conditioner."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Heiney your right. It seems confusing. I just sent adcom an email asking about what we have just disgusted.
Truly though everyone should look into a power surge protected circuit breaker box.
From what i am told they are not that expensive and they will protect the whole house at the source of the power.
Then i found these
http://www.audioadvisor.com/prodinfo.asp?number=MITZDUP&variation=20A
I seem to have an issue once I have something in my head, and right now that is making sure everything is powered and protected properly, I cant stop till I have everything in order.
I am totally obsessive compulsive.Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
Rocco, I agree a dedicated circuit is always better, but it's not necessary. Adcom should get you straightened out and on the right path. Surge protectors and line conditioners will work as well. With a high power multi-channel amps careful choosing is required to get optimal results in all listening situations. Whole house surge protection is a great idea as well.
this may be the new answer!!!
i am gitty
http://www.psaudio.com/ps/products/detail/power-plant-premier?cat=powerMan Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
Yep, that would do it!!! My brother just bought a used one for his BAT VK120 tube mono's. It's not hooked up yet."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Maybe you can gets some feed back from you bro. when he has played with it for awhile.
I am going to do some major digging in the mean time.Man Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
i am gitty
How crappy is your power coming into the house that you would need such a beast? yikes. -
jin its not about being crappy its about getting the best out of your system. plus i am willing to invest.Man Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
you and I are going to be great friends, in fact I have some Rocco family cousins in Chi-town.;)
RT1 -
RT1
Yah, Rocco is not a popular name. The only ones i know are me and my cousin.
Does anyone have any experience with the PS Audio products. They seem built proof.
I watched a few videos on them last night. The Power Plant Premier Acutally stores power and can kick out up to 50amps in a high demand situation.....i think someone earlier said something about that...hmmmMan Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
PS Audio stuff is built and designed very, very well. No worries there Rocco. I'm hoping we can start putting together my brothers system this weekend. He just moved into a new house and there are lots of things to do before getting the system up and running. he will have an electrician there this week running dedicated lines, etc and getting the listening room ready for the gear.
I'll comment in here once we start using and setting up the power plant premier he has."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
I so miss those amps.......................................:(
I used a Shunyata with that pair of tubed BAT's, easily passes 20 amps I also used it with a huge BAT sand amp the VK-500 and it never skipped a beat, I did try and use the PS Audio UPC-200 with the VK-500 but no good, the sound stage was limited and collapsed back onto itself as that product cannot handle the large current draw. The UPC though does a great job with the rack gear where I use two of them.
RT1 -
The yikes was meant to convey 'tongue in cheek' :eek::D
That is a really sweet looking power re-conditioner. -
reeltrouble1 wrote: »I so miss those amps.......................................:(
RT1
Well, I've had my ears on them twice for short periods. They are still at our friend Rob's house. They are sweet amps, that's for sure!!! And very delicious to look at!!
I have been looking at the UPC-200 for the 2ch rig. It should suffice for my needs."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
