Receiver Help?
yanoutha
Hi,
I have received as a gift, the Polk RM 6750 surround speaker system. I know they are very entry level, but am deciding to keep them for my place. I live in a one bedroom condo so I assume they should be fine. I would like to buy a receiver but do not want to spend more than 200 - 300 canadian dollars.
Could someone recommend a good receiver in that price range? I do not mind if it is used either.
Thanks,
John
Thanks,
John
Post edited by yanoutha on
John, welcome to the forum. A sure bet for what you are looking for can be found in the Marketplace here on Club Polk. I just bought one there for a friend of mine for $100USD. Be sure to read all of the pages as there are many things for sale and what you are looking for may be back on page 8 or 10. Good luck in searching.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Hi,
Treitz3 is right. You could also look for an entry level Onkyo 505/6, could maybe find that on sale for near your price? Plenty of power for that Polk system.
I'm using a Yamaha RX-V663, which falls in that price range on sale. A nice AVR with tons of features to tweak with. There's a thread devoted to it over in the AVR forum. It is last year's model now and many e-tailers have been aggresively pricing to get them cleared out. Highly recommended.
Canuck audio mart is another place to look...
http://www.canuckaudiomart.com/ if you even remotely think you may upgrade at any point, look for on that packs as many features as possible, such as Pre-outs, which are used for adding external amplification and HDMI. I know the Yamaha RX-v861 is available in the used catagory with those features and close to that in price.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thanks to all for your help and suggestions. It is definitely putting me in the right direction.
Regards,
John
