zone2 issues on sc-07
doggie750
hello polks,
i have read the manual 10x and still no luck, i'm unable to get my 2 towers to engage with the sc-07 in the adjacent room. pioneer cust service was no answer so i'm hoping i could get some advice from mi familia in polktown:):):D:D. no external amp connected just straight from the new comer, sc-07. thank you.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
You need run them on zone 2 speaker terminals, then press zone two on the remote to engage them.Shoot the jumper.....................BALLIN.............!!!!!
Zone 2 is a little tricky if you never done it before. So I will walk you through it.
1) Go into the onscreen menu and setup the zone 2 amp.
2) Switch the factory remote switch to zone 2
3) Turn on zone 2, it will say it on the front of the Sc-07
4) select a source
5) turn up the zone 2 volume.
Note: You must connect a analog cable to the analog inputs for every device you wanna listen to in your zone 2. Internal tuner and Ipod front connect will also pass into zone 2. No HDMI signal will pass so if your trying to use a Blu ray player as a Cd player and don't have analog going to the "cd" input, you will have no sound.
Also make sure you wired your speakers to the Surroundback/zone 2 speaker outputs.
So I suggest you follow these directions and you will be enjoying your zone 2 in no time.
DanDan
.....done this in the beginning
4) select a source
figured this out last night and this where the sc-07 FAILED, was hoping i'll get some digital runs here :mad::mad::mad:
as mentioned this was done however i have my rear surrounds and my zone2 towers engaging @ the same time. my hope is to get my towers only, guess i have to set is as speaker B only and i need a lot of luck on that.
Dan
THANKS much to Sherap & mantis....:):):)Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
