hi, wut cable I need to connect a receiver and a amplifier?
woweu2006
woweu2006 Posts: 68
And how much it cost?
I am a noob.
:D:D:D:D:D
Sony BRAVIA W-Series KDL-52W4100
Polk Audio LSI15 - Front
Polk Audio LSIC - Center
Polk Audio PSW10 - Sub
Polk Audio R50 - Surround
Playstation 3 80GB - Blu-Ray Player
Denon AVR-989
Denon 758
http://californiammo.com/
:D:D:D:D:D:D:D:D
Post edited by woweu2006 on
    F1nut Posts: 51,761
    edited April 2009
    Something wrong with the schools in Fremont or is English not your first language?
    You will need a set of RCA (analog) cables, run from the pre out connections on your AVR to the power amp. They can cost from a few dollars to tens of thousands.
  • DollarDave
    DollarDave Posts: 2,575
    edited April 2009
    He doesn't have time to spell correctly, he is sprinting to 25 posts so he can sell his R50s in the flea market.
    F1nut Posts: 51,761
    edited April 2009
    It's unfortunate when folks waste other folks time with meaningless posts. I guess he'll find out soon enough how unfortunate when his stuff doesn't sell.
  • george daniel
    george daniel Posts: 12,096
    edited April 2009
    If only I could master the multi quote,, sigh,,, why do some cables cost tens of thousands?Do they make a difference?;)
  • superjunior
    superjunior Posts: 1,632
    edited April 2009
    Hopin someone can field a simmilar question from another noobe. I picked up a pioneer92 with the intent of NOT getting an amp, the more I research, the stronger the urge. Oh, what the hey, I can't fight it anymore, looking towards the emotiva xpa-2 or 3. Question is, does the amp have its own sepperate volume control, or is it run off the receiver volume ? If not controlled by the receiver, how do you ballence things out so the channels not driven by the amp are not drowned out by the ones that are ? Thanks ahead
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • McLoki
    McLoki Posts: 5,231
    edited April 2009
    Probably not with R50's.... (ok, a little - but in that system, it would not be the best use of your money.) :D
  • george daniel
    edited April 2009
    Your reciever should have "pre out",,that way it controls the amp,which does not have a seperate volume control.In other words,, the "control" portion of the rec. vol/bal/etc,, controls the power amp. Good luck.
  • superjunior
    edited April 2009
    Thank you, sounds pretty simple. Funny how all this started with our old tv needed to be replaced....my wife thinks I should see a shrink :D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • george daniel
    edited April 2009
    Careful,, it's just starting,, many of us have been down the path that you may be headed,,look out for the rabbit hole,, see you there;)
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    can you give me a link and brand of your cables pls?
    many ppl say Monster cable is the best, but most expensive, right?
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
  • Conradicles
    Conradicles Posts: 6,342
    edited April 2009
    woweu2006 wrote: »
    Welcome to Club Polk.;)
  • george daniel
    edited April 2009
    woweu2006 wrote: »
    Call Frank at Signal Cable,, he'll hook you up,, good solid cables at a reasonable price.Good luck,have fun and enjoy.
  • zarrdoss
    zarrdoss Posts: 2,562
    edited April 2009
    had real good luck with these if your on a tighter budget
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=181-652
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    thanks a lot for the info.
    I am sure, your guys' post help a lot noobs like me.
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
  • Mike21
    Mike21 Posts: 252
    edited April 2009
    Hi Woweu.
    Forget Monster and Phillips.
    Go with either Blue Jeans, Signal, Monoprice, Sonic Wave @ Parts Express, Zebra or Element.
    Mike
    ____________________________________________
    Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
    PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors.
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    cool, thanks.
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
  • lightman1
    lightman1 Posts: 10,796
    edited April 2009
    big ones..really, really big ones...
    ..:) Blue Jeans or Signals...My opinion though.
    edited April 2009
    Say Wow!!!!!!,
    Have you by any chance 'read' your own post 'history' because "I" have. Just what is it that you're up to? So far you've been interested in getting an Acurus power amp for your LSI-25s; then you had ordered a great set of RTI towers and center at a deal that "we" could also get if we called a 'number'. One of you're original posts had a .com sales link? Then you had a post telling us how R50s or R300s, I can't remember which? Were the best SPEAKER Polk made better than than those overpriced pretender RTIs and LSIs...and what a great price you could get them to us?
    Now you 'don't' know what kind of cables to use (been reading the cable threads here, have you?). I would think that someone who owns almost the entire inventory of current Polk speakers could answer that question. Don't you?
    cnh
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    as i said, I am a noob.
    I own R50 and CSI25. I plan to upgrade.
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
  • lightman1
    edited April 2009
    He's trying to sell them...
  • lightman1
    edited April 2009
  • superjunior
    edited April 2009
    Not too sure what the rabbit hole means, but my wife saise if she sees another new componant on our rack or new remote on the table (tried telling her,"we've always had that", only worked the first time) she'll be digging me a hole in the backyard :p
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2009
    That's where the ole' "I was driving along and what do I see sticking out of someones garbage can? This 1800 dollar amplifier!! Can you believe my luck", story comes into play.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • george daniel
    edited April 2009
    Key word is "sees";)
  • mr2sw21
    mr2sw21 Posts: 115
    edited April 2009
    sorry to ask and not trying to upset anyone. But is monster really that bad?
    I have seen they are really expensive in the store? Just over price?
  • Face
    Face Posts: 14,340
    edited April 2009
    They have very poor business practices.
  • superjunior
    edited April 2009
    Brilliant !! Haven't tried that one yet, tried the old 20.00 price tag on the new toy trick " look what was on sale honey, an 1800.00 amp for 20 bucks ! I saved us 1780.00" now I deserve a nice dinner and a backrub :D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    edited April 2009
    She sees all :eek:
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • woweu2006
    woweu2006 Posts: 68
    edited April 2009
    Kex wrote: »
    No, Wow, very wrong (according to 99.9% of Polkies ... the other 0.1% were hopelessly drunk at the time of their response)!
    Perhaps the cheapest, and most readily available decent cables (many consider these equal to Monster in quality):
    - http://www.monoprice.com/home/index.asp
    Better, and easy ordering over the internet (vastly superior to Monster):
    - http://bluejeanscable.com/
    - http://signalcable.com/
    Possibly the best quality you'll ever find under $100 per pair for IC cables (if you mention "Monster" in his presence, he turns green and becomes "very angry". You won't like him when he's angry:
    - http://www.polkaudio.com/forums/showthread.php?t=71890
    After that, the sky's the limit, but you should try to keep some synergy in your system (you wouldn't put racing tires on a Toyota Yaris, would you?).
    hey, thanks.
    i ordered 10 cable from http://www.monoprice.com/home/index.asp
    they arrived in 24 hours. amazing.
    thanks
    Denon AVR-989
    Denon 758
    :D:D:D:D:D:D:D:D
