DUELUND resistors
fbm211
Im looking at these on parts connection and thinking of ordering the 2R7 which I think is the right value for the 2b xover.Would these be better than mundorf resistors or mills??? I am going to an interview for a new job today and will buy some goodies for my gear if I get the job:eek: Like some cardas or WBT binding posts,dayton 1% caps and some silver sonic hook up wire.And a pair RDO194s of course.:D http://www.partsconnexion.com/t/catalog/resistors.html
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Why would you spend more on resistors than capacitors?
No slight sheen like Mundorf, no coloration or extra warmth like Mills, Duelund are transparent as possible.
I would recommend the TL upgrade(5.8uf + RD0-198) and a better grade of capacitors for your 2B's if you're considering parts from WBT and Duelund. The TL upgrade alone would be a substantial upgrade over your current 2B's."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I agree with Face. If your going to get into it, go for the upgrade. Why half step? The tweeters cost the same...
One other thing, Duelunds's capacitors are a great match for their resistors. Just don't cheap out and buy the aluminum ones.
These are reasonably priced !!!:eek:
http://www.electrumaudio.com/magento/index.php/duelund-20-0uf-cast-pio-silver-foil-paper-in-oil-crossover-capacitor.html -
OK 15.00 for a resistor but thousands for the caps.I can afford the resistors but not those caps.DAMN....I guess I can go with soniccaps on the high pass since I will need to get 2-5.8uf and 2-12uf....Do the mundorfs add a little zing to the highs??Thats what I want----not the warmth the mills are said to have.SDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
For "ZING"....just keep the SL2000s!:eek:
The caps listed above are probably the most expensive they make. For a pair of 2B's, you would still be looking at $1,500 for the high pass though. :eek:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The SLs are starting to grate on my nerves.Im sure some of you know what I mean.Candy liked them though.lol...Ill stick with sonicaps.I have considered V-CAPS for the high pass.That would cost around 180.00....Sonicaps all around or daytons if Im feeling cheap.The 20% off sale at soniccraft has ended.bummerSDA-2BTL with custom IC
If you don't want to spend a lot, I would use Sonic Caps on the HP and Dayton on the low pass."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
