will any of these polyswitches work in my 2.3tl's?
zarrdoss
zarrdoss Posts: 2,562
edited April 2009 in Vintage Speakers
Not having any problems yet but was wondering if any of these would work in my 2.3tl's? I was going to place a PE order soon and was going to throw some of these on here if they would work.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=&search_type=main&WebPage_ID=3&searchFilter=polyswitches&x=24&y=5
  • Unknown
    edited April 2009
  • zarrdoss
    edited April 2009
    cool thanks
  • amulford
    amulford Posts: 5,020
    edited April 2009
    Take them out and jumper it with good quality wire. You don't need them...
  • inspiredsports
    inspiredsports Posts: 5,502
    edited April 2009
    amulford wrote: »
    Yes they are a huge compromise, but with all due respect I would qualify that advice.
    --- If you have clean audio sources and are reasonable about turning your volume down if you sense distortion, remove and "jumper" them.
    --- If you crank it with reckless abandon and/or have low quality sources/amps/etc., replace them.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • AudioGenics
    AudioGenics Posts: 2,567
    edited April 2009
    good info
  • inspiredsports
    edited April 2009
    good info
    Um, yeah, . . . that's why I offered it. I'm not in the habit offering bad info.
    NAD SS rigs w/mods
    GIK panels
  • amulford
    edited April 2009
    Excellent advice. I was hoping he already knew it...
  • zarrdoss
    edited April 2009
    amulford wrote: »
    I did from previous threads but after just spending $300 for new 198's and my luck I figured all the insurance I can get. Polk CS is awesome sent me 4 new ones and got them in two days! I will install when I really get bored.
