will any of these polyswitches work in my 2.3tl's?
zarrdoss
Not having any problems yet but was wondering if any of these would work in my 2.3tl's? I was going to place a PE order soon and was going to throw some of these on here if they would work.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=&search_type=main&WebPage_ID=3&searchFilter=polyswitches&x=24&y=5
cool thanks
Take them out and jumper it with good quality wire. You don't need them...
Yes they are a huge compromise, but with all due respect I would qualify that advice.
--- If you have clean audio sources and are reasonable about turning your volume down if you sense distortion, remove and "jumper" them.
--- If you crank it with reckless abandon and/or have low quality sources/amps/etc., replace them.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
good info
joseph.v.chen wrote: »good info
Um, yeah, . . . that's why I offered it. I'm not in the habit offering bad info.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »Yes they are a huge compromise, but with all due respect I would qualify that advice.
Excellent advice. I was hoping he already knew it... -
I did from previous threads but after just spending $300 for new 198's and my luck I figured all the insurance I can get. Polk CS is awesome sent me 4 new ones and got them in two days! I will install when I really get bored.
