CD players?
VR3
What CD players is everyone using? Why did you pick it? What other equipment are you using?
I have had my eye on Wadia, Symphonic Line, Bryston, and upper end Shanling, Mcintosh
I think the Shanling is one of my weaker links...
Id like to keep it under 1,500-2,000 and I prefer used (but only a few years old)
Open to just about any suggestion. Give you an idea of what I like - I like in your face dynamics and as much detail and definition as possible. I do NOT****** want a tube CD player. I have never used the tube portion of my CDP and think to many tubes is a horrible thing...
So solid state CDP is my prefered. I just want a CDP with the lowest noise floor and good dynamic range --- but I do not want it to mask any details from my setup!
Thanks!
Thanks!
Post edited by VR3 on
I can tell you that you DON'T want a McIntosh in that price range, avoid the 201 like the plague.
Given your description above, you should add the Cambridge 840C to your list."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Marantz SA-11S1 on the used market is a great player and its in your Price range:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
The Cambridge 840C seems to be the latest giant killer...of course the Rotel 1072 is a classic BARGAIN.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Esoteric X-03. Good for both SACD and redbook playback. I think I made the right choice.
Good luck Sid.Michael
NORTH of 60° -
Its also does SACD very will:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I couldn't resist the deal from Audio Advisor for an open box Cambridge 640c v2 with dual Wolfson DACs (yeah - I succumbed to the hype, but so far I am impressed).
I have it hooked up via some AQ Copperheads to my AVR which I put into Pure Direct to maintain the analog path from the CDP.
Very decent mid-priced CDP -esp for the discount.
That Esoteric is awesome, but a little out of my price range (just a quick search on Audiogon..)
Someone told me the Bryston BCD-1 would be perfect for my needs and sound taste, any experience here?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I recently heard the Bryston and a couple of SimAudio CDP's. The SimAudio Equinox was very impressive. Pretty similar sound between the Bryston BCD-2 (I need to check and make sure that's the right model that we were listening to!) and the SimAudio CDP's. SimAudio did have the edge on the noise floor, it seems to be a characteristic of SimAudio gear that they have an absolutely black background.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Heard it, loved it,but can't afford it.:(Vr3MxStyler2k3 wrote: »Someone told me the Bryston BCD-1 would be perfect for my needs and sound taste, any experience here?Testing
Testing
Testing -
I am totally hooked on Accuphase CDP and there are some used ones on Audiogon for around or below $2000 range.
It's all SS Design. Accuphase Engineering and the craftsmanship is really a step above most others CDP in the market and comparable to higher end ones in the market. Besides, some models have excellent DAC and I have 1st hand witnessed an Accuphase CDP hooked up to my Oink Grand Integra M-510 amp with very positive results.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
My player is passable but nothing special like most of the gear mentioned above. But I have heard a McIntosh, recently, in that range and I was thoroughly 'under-impressed' I couldn't believe how mediocre it sounded, not much better than my player...which doesn't even deserve to be mentioned with the likes of some of the above...
My next player will likely be a Cary tubed player -- probably a 306/200 or something comparable.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
What about a Media center? using a hard drive? All your music stored in a Lossless format bit for bit. No scratched disc's, no changing disc's, think about it man. It's the way I'm going.
DanDan
Allow me to second the advice Face gave you above. Do NOT buy a 201 from McIntosh, I don't care what type of deal you can get. I had 2 with the first going back 2 times and the second one having several problems. Now if you can step it up to the 500, you're in a different league. What a wonderful player! I was thisclose to buying the 500 and my dealer gave me an offer on the MD1K I could not refuse.
Again, stay away from the 201.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
What is so wrong with the 201? I just gotta know.Allow me to second the advice Face gave you above. Do NOT buy a 201 from McIntosh, I don't care what type of deal you can get. I had 2 with the first going back 2 times and the second one having several problems. Now if you can step it up to the 500, you're in a different league. What a wonderful player! I was thisclose to buying the 500 and my dealer gave me an offer on the MD1K I could not refuse.
Gordon
DanDan
cnh
Was it the 201?
Gordon2 Channel -
Dan
Well Dan, it is junk. Cut and dried. The drive was noisy enough to hear across the room even with music playing! It would lock up, skip and randomly not read a disc. When working, it was not a bad machine maybe equivalent to a Denon 2900 perhaps slighty above. But for the price they were getting the noise and lockup issues should not have happened. I'm a McIntosh nut to the end but they screwed the pooch on this piece.
An insider I know told me that it was rushed through production and no Beta testing was done to find the faults. Actually to bad because it could have been a nice entry level McIntosh piece.
Gordon2 Channel -
And just when I thought you developing an appreciation for musicality.Political Correctness'.........defined
President of Club Polk -
Dan
I like the simplicity of popping in a CD and playing it. I'm not saying that a media-center approach doesn't have its pluses, because it does, but I think there's a lot to be said with a good old CD player too. I don't like having to rip CD's, manage a library, create playlists and hunt for songs. I do it with my IPod (barely) but much prefer just putting in a disc, kicking back on the couch, and listening to it.Speakers: Polk LSi15
Another comment. If you have never used the tube output, how do you know what it sounds like???Political Correctness'.........defined
I see. I once thought as you do until I got the SC-07 receiver and heard my Ipod for the first time clearly. I had a 1/8 inch stereo to rca cable and tried listening to my ipod on my Rotel. No dock or digital connection, just analog and I thought it sucked. It was ok I guess , sucked is strong but it sounded nothing like it does now. And I even had recording in Lossless then.
after a few hour conversation with a fellow audiophile, I personally am eager to build a media Pc or buy a media center of some sorts. I plan on spending some quality time researching this very Idea.
I really like the idea of all my media stored in one place. How cool would it be to dial up a movie or song you wanna hear/watch? There is some really good media centers out there, we have the Elan VIA DJ at work, I'm not sure how good it is for sound quality as I only listen to it with a house system with mostly inwall speakers. But I like the idea.
DanDan
By media center, do you mean a Media PC?SDA 1C, SDA 2A, SDA SRS 2, CMT-340SE, Swan M200MKII, Swan D1080MKII, Behringer MS40
Outlaw Audio M2200 x2, GFA 555 II, BGW 750C
GDA 700, Outlaw Audio Model 990, Sansa Fuze, X-Fi Platinum Fatality -
Sony 5400ES SACD player with XLR outputs, $1499 list, but $1100 at various online stores. For CDs, the 5400ES is a digital transport feeding a Benchmark Dac1. For a multi-mega-CD-changer, a music server into the Dac1 is the ticket.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
How do you like the Sony 5400ES sacd player?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I like it as a single disk SACD player, and it has XLR, RCA, and HDMI output, which supports Sony's jitter free technology HATS over the HDMI link. If you have pre-amp which supports HDMI and HATS, or equivelent, it would be a good combination. HDMI is the only way to get multi-channel SACD playback as analog is only 2 channel. It does not have a digital input for using its DACs with other devices.
The player appears based on the Sony 9100ES DVD/SACD player, which I use in the HT room, and is heavy, solid, very well constructed, and, to me, sounds great for SACDs. I think the digital output to the Dac1 sounds better for CDs than does the 5400ES.
Unfortunately, I cannot give a comparison, such as it sounds better/worse than player "X", since it replaced my 1999 DVD/CD player which I was using as a CD digital transport into the Dac1, and, obviously, could not play SACDs. I can say there are some hybrid disks which will not play on the DVD player, but, so far, I have not had any issues with the 5400ES in that area.
I was amazed Sony released this player in November 2008 since the SACD market is suppossed to be going away. Aside from needing an SACD player with XLR output in the 2 channel setup, and being very pleased with the 9100ES as both a DVD player and an SACD player, my logic in buying it was if Sony is going to release a dedicated ES SACD player in a declining market then it must have something going for it. Of course, that could be faulty logic, and it is a just an average SACD player, but I hope not.
Why not just add an outboard DAC?
I used to have the 9100ES multi-SACD player. I thought it was very good on SACD
playback. Im very interested in the 5400ES. ThanksLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Grab the PS Audio DLIII for $695 while you can. It may the answer you are seeking, or at least the beginning of the path.DKG999
Anything with Wolfson DAC's will be analytical which I believe are the characteristics you seem to favor. Me personally, I find Wolfson DAC's to be a bit too "in your face" and analytical and uninvolving. It is possible to get something less analytical but still not miss any detail.
The Cambridge's or Rotel's come to mind for being a bit more forward and analytical as well as providing good dynamics."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
