Jaguar vs. King Cobra vs. Diamondback
Norm Apter
Norm Apter Posts: 1,036
Certainly don't want to inadvertantlly initiate another "cable debate" but I would like to hear about any listening experiences folks have had who have sampled a combination of three audioquest types of interconnects listed belown, namely
Diamondback vs. King Cobra
OR
King Cobra vs. Jaguar
I have found plenty of threads on these cables individually through the search feature, but haven't seen any direct comparisons.
big difference? subtle difference? what kind of difference?
Norm
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • mantis
    mantis Posts: 17,339
    edited February 2009
    Small differences as you go up the line. There entry level cables at the Sidewinders do nothing wrong man. They are excellent cables but as you move up the line, you start to hear little things that you didn't as well in the lower end cable.
    I have heard them all and shot out a lot of Audioquest cables. The Jaguars are incredible cables and I wired my entire system with them.
    The Diamonds and Kings are damn close. Not much difference. You have to struggle to hear them small differences . Both cables are fantastic.
    Dan
    Dan
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Norm,My first A/Q i/c was Copperheads...Then I moved into King Cobras which I currently have in the 2-channel rig.
    The difference between the Copperhead and the Cobras was a pretty big step,the Cobras are very smooth,yet detailed.
    I've bought all of mine used from e-bay or A'gon...I simply can't afford high priced cables and the King Cobras are far better than average i/c's for the money.
  • phipiper10
    phipiper10 Posts: 961
    edited April 2009
    Just reviving this as I had the exact question Norm originally had specifically from those with Jaguar experience relative to either of the other two cables mentioned.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
