over my head :)
boombozz
boombozz Posts: 5
I am new to Polk and wanted to get in over my head so I bought the LSi15s.
I will be hooking them up to a Yamaha RX-V663 as a "pre-amp" with a Parasound AMP (4ohm) for just my LSi15 front set. I will hopefully be adding a center channel and backs soon. Any comment on the back or center speakers - do they have to be LSi or are there other alternative matches? I also want to see how the bass is with the two 8in woofers in the LSi15 but I may also be adding a sub. I cannot wait to hear these speakers. Thanks for any comments.
Post edited by boombozz on
  • thsmith
    thsmith Posts: 6,082
    edited April 2009
    Center should be matching timbre, rears are not so critical
  • PSOVLSK
    PSOVLSK Posts: 5,419
    edited April 2009
    I would definately go LSi for the center. I'm happy with my LSiC, but others might recommend a single LSi7 or 9.
    For surrounds I always thought it didn't matter too much...until I moved my 7's to surround duty. If you listen to concert DVD's in multi-channel it makes a big difference. For movies, I can't say the improvement over the Fxi A3 is huge.
    Bottom line for me is that I have put my system together little by little so I've had various fronts, surrounds, etc., and I am VERY happy with my system now.
    Almost forgot. For me, the bass with the LSi 15 was not enough for movies. I currently use my 15's in a music only system, so I am obviously content with the bass for music.
    Hope this helps.
  • raidersrule76
    raidersrule76 Posts: 471
    edited April 2009
    +1 one the center. what Parasound amp did you get? I love all mine so far.
    Sig to be updated after dealing with the insurance company:(:(:(
  • boombozz
    boombozz Posts: 5
    edited April 2009
    I thought I would start with the Parasound 275 Clasic (two channel) and when I upgrade I can always use it to power somthing else - like subs. I think it will do the job.
