DIY power cable recipes...
steveinaz
steveinaz Posts: 19,546
edited March 2009 in DIY, Mods & Tweaks
Anybody got some good links and/or recipes for home-made AC cables? I have always wanted some custom lenth power cables for my system, to get rid of clutter. Where can I find IEC's, cable, plugs that are good but crazy expensive...
  • ND13
    ND13 Posts: 7,601
    edited March 2009
    steveinaz wrote: »
    How crazy expensive do you want em to be?;)
    http://www.mouser.com/search/Refine.aspx?N=4206622&utm_source=google&utm_medium=ppc&utm_campaign=mouser
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • zingo
    zingo Posts: 11,258
    edited March 2009
    VH Audio will be able to hook you up with whatever your price range (up to $1000 per meter :D). The have raw cables, connectors, shrinks, etc.
    FYI: I have made my own power cord before, and I have found that a lot of the DIY power cables are rather stiff; more so than my liking.
  • steveinaz
    edited March 2009
    Opps, I meant NOT crazy expensive. You know, a giant killer home-brew cable, on the cheap.
  • ND13
    ND13 Posts: 7,601
    edited March 2009
    I knew from your own words.."I'm cheap" what you meant, that's why I put up Mouser. I expect they sell hospital grade connectors that won't cost you $40+ each.
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2009
    Hospital grade is intended for hospitals. Sure, you can expect better quality control, but they're meant to have corrosion resistance, not necessarily electrical resistance.
    treitz3 Posts: 20,342
    edited March 2009
    I have had good experience with Analysis Plus SC and if you find the right supplier, you can order how ever many feet you want. Then just choose the termination of choice and whalla. Not too terribly expensive with a good end result as to what hits your ears.
  • steveinaz
    edited March 2009
    Man, I was hoping for some pics...some how-to, that kinda stuff.
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2009
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • bikerboy
    bikerboy Posts: 1,242
    edited March 2009
    I sold the PS Audio pc after I made the various VH Audio pc. I like the ability to make custom lengths and like the way they sound. Their website has good descriptions on how to make them. I use the Furutech ends and the VH Audio wire. Very well made and easy to use and sounds very clean and clear.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited March 2009
    I am using VH audio power cords also.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
