DIY power cable recipes...
steveinaz
Anybody got some good links and/or recipes for home-made AC cables? I have always wanted some custom lenth power cables for my system, to get rid of clutter. Where can I find IEC's, cable, plugs that are good but crazy expensive...
Post edited by steveinaz on
How crazy expensive do you want em to be?;)
http://www.mouser.com/search/Refine.aspx?N=4206622&utm_source=google&utm_medium=ppc&utm_campaign=mouser"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
VH Audio will be able to hook you up with whatever your price range (up to $1000 per meter
). The have raw cables, connectors, shrinks, etc.
FYI: I have made my own power cord before, and I have found that a lot of the DIY power cables are rather stiff; more so than my liking. -
http://www.parts-express.com/power-electrical.cfm
http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=478&CFID=572300&CFTOKEN=74707960
http://www.partsconnexion.com/t/catalog/connectors.html
http://www.partsconnexion.com/t/catalog/wire.html
http://soniccraft.com/products/connections/ac.htm
http://soniccraft.com/products/wire/ac.htm"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Opps, I meant NOT crazy expensive. You know, a giant killer home-brew cable, on the cheap.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I knew from your own words.."I'm cheap" what you meant, that's why I put up Mouser. I expect they sell hospital grade connectors that won't cost you $40+ each."SOME PEOPLE CALL ME MAURICE,
Hospital grade is intended for hospitals. Sure, you can expect better quality control, but they're meant to have corrosion resistance, not necessarily electrical resistance.
I have had good experience with Analysis Plus SC and if you find the right supplier, you can order how ever many feet you want. Then just choose the termination of choice and whalla. Not too terribly expensive with a good end result as to what hits your ears.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Man, I was hoping for some pics...some how-to, that kinda stuff.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Have you tried www.diyaudio.com or www.diyaudio.com/forums ?Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I sold the PS Audio pc after I made the various VH Audio pc. I like the ability to make custom lengths and like the way they sound. Their website has good descriptions on how to make them. I use the Furutech ends and the VH Audio wire. Very well made and easy to use and sounds very clean and clear.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
I am using VH audio power cords also.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
