advice please
looking to upgrade what should i use for front surrounds have CSi A4 as center will move rm 201 to rear Ty
Post edited by mikeperk on
Any of the speakers from the RTi series will match the CSi A4. Are you looking for bookshelf speakers or floorstanders? What's your budget? What are you driving the speakers with?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
bookshelf would be perfect have about $500 I have a onkyo 606comfortablycurt wrote: »Any of the speakers from the RTi series will match the CSi A4. Are you looking for bookshelf speakers or floorstanders? What's your budget? What are you driving the speakers with? -
RTiA1 or 3 should work. Check Polk Direct on ebay. Any of the RTi series BS will work with your center.Speakers: SDA-1C (most all the goodies)
Go for the RTiA3s:DLinn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
If you can find any. The RTI6's would be good. I just bought a pair recently and I am really pleased with them. I got them for $200.00 cnd
good luck"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
I've got the same AVR...great entry level receiver.
Any of the RTi series bookshelves would work. Either the RTi A1's or RTi A3's will match well with the CSi A4. You could save a little coin to put towards other parts of your setup by getting the older versions of those speakers too, the RTi4's and RTi6's.
With a budget of 500 bucks, what I'd do is get a pair of RTi6's for the fronts, and replace the RM's with some RTi4's for surrounds. You'd have a fully timbre matched setup then. If you shopped around for a good deal, you could probably get the RTi A3's and RTi A1's for under 500 too.
Check Polk Directs ebay store. They've usually got great deals on refurbished speakers.The nirvana inducer-
Am looking to buy some used Bs RTi 's any body know of some sites none on e bay Ty Mike
Have you tried CL ?Speakers: SDA-1C (most all the goodies)
