advice please
mikeperk
mikeperk Posts: 4
edited April 2009 in Speakers
looking to upgrade what should i use for front surrounds have CSi A4 as center will move rm 201 to rear Ty
Post edited by mikeperk on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited March 2009
    Any of the speakers from the RTi series will match the CSi A4. Are you looking for bookshelf speakers or floorstanders? What's your budget? What are you driving the speakers with?
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • mikeperk
    mikeperk Posts: 4
    edited March 2009
    bookshelf would be perfect have about $500 I have a onkyo 606
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    RTiA1 or 3 should work. Check Polk Direct on ebay. Any of the RTi series BS will work with your center.
  • danz1906
    danz1906 Posts: 5,144
    edited March 2009
    Go for the RTiA3s:D
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • renowilliams
    renowilliams Posts: 920
    edited March 2009
    If you can find any. The RTI6's would be good. I just bought a pair recently and I am really pleased with them. I got them for $200.00 cnd
    good luck
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • comfortablycurt
    edited March 2009
    mikeperk wrote: »
    I've got the same AVR...great entry level receiver.
    Any of the RTi series bookshelves would work. Either the RTi A1's or RTi A3's will match well with the CSi A4. You could save a little coin to put towards other parts of your setup by getting the older versions of those speakers too, the RTi4's and RTi6's.
    With a budget of 500 bucks, what I'd do is get a pair of RTi6's for the fronts, and replace the RM's with some RTi4's for surrounds. You'd have a fully timbre matched setup then. If you shopped around for a good deal, you could probably get the RTi A3's and RTi A1's for under 500 too.
    Check Polk Directs ebay store. They've usually got great deals on refurbished speakers.
  • mikeperk
    mikeperk Posts: 4
    edited April 2009
    Am looking to buy some used Bs RTi 's any body know of some sites none on e bay Ty Mike
  • thsmith
    edited April 2009
    Have you tried CL ?
