Tubes -vs- SS on SDA's
treitz3
Ok, I have heard SDA's on both and I have my own observations on both and will reserve my opinion of both until later on in this thread. I was just wondering what your observations as to bringing out the best that SDA's have to offer. What do you prefer and if you don't mind me asking, why?
All tubes from source to speaker? Tube pre with SS amp, tube source? No tubes at all? What have you had [not read about] that gave you the best synergy when it comes to SDA's?
The best my SRS 2s ever sounded was with Dodd ELP and Anthem Amp One(40wpc)."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
What I listen to at Caverfest, I would say tubes hands down.engtaz
Noel, I'm expecting to get that very same [the actual] Anthem amp you had shortly and I'm looking to have a Dodd tubed pre in the mix as well. This will be teamed up with the Jolida JD100 and augmented with a VMPS Larger sub powered by an Odyssey Stratos and the Velo SMS-1 to integrate everything.
At least that's the plan.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Tubes,, specifically,,Noel's Anthem,,with upgraded Jenzen PIO caps,,winged "C" EL-34's,Brimars and NOS RCA,,Dodd MLP and believe it or not an old Rotel 855. Tubes,at least in the pre and power components.:)JC approves....he told me so. (F-1 nut)
for me, it would be a combination of a ss amp driving the midbase drivers and tubes on the tweets. I remember seeing a setup like that at shellys audio in L.A.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
*clears throat*~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Tubes, stupid! You've heard them and now ask others for justification! Grow a set Tom and damn the torpedoes. My sons will tell you what you want to hear tomorrow. Chump!
george daniel wrote: »Tubes,, specifically,,Noel's Anthem,,with upgraded Jenzen PIO caps,,winged "C" EL-34's,Brimars and NOS RCA,,Dodd MLP and believe it or not an old Rotel 855. Tubes,at least in the pre and power components.:)
Well George after hearing the EL34's at my place I have had a different feeling about tubes. Agian it was an experience I will never forget.
Ben -
On the SDA, I prefer tube on the pre vs my SS pre. The sda are bright to begin with and the tube pre helps to calm it down a bit and make the warmer sounding.
I can't comment on a tube amp becuase I don't own one yet.. -
Erniejade, do your SDAs still have the original tweeters, or the RDO replacement ones ?? The RDOs take away a lot of the brightness,at least they did on mine, and my setup is all SS. (no tubes yet) -
Sig material here,,,"tubes,,stupid"JC approves....he told me so. (F-1 nut) -
Ben
You are right,, it just all came together,, it's difficult to explain,, you had to be there to understand.Even my brother,who is very familar with my gear,was blown away,,he thought that I was auditioning/evaluating a NEW amp,, Nope,, 40 watt;s of tube power,,,eh,, you just had to be there.Lastly,,, to borrow a term from RT1 and Manley
Tubes RuleJC approves....he told me so. (F-1 nut) -
Say it ain't so George!!!!"SOME PEOPLE CALL ME MAURICE,
Beautiful
Welcome back! -
using digital sources - Solid State
using analog sources such as records - Tubes -
not to worry,, Tom and I have an arrangement,it will not be leaving the "family",,,,FWIW,, my wife almost cried when it left,,she helped me install the Jenzens in it,,it is a very "magical" amp.JC approves....he told me so. (F-1 nut) -
nevermind, it's useless"SOME PEOPLE CALL ME MAURICE,
joseph.v.chen wrote: »using digital sources - Solid State
I am going to have to disagree on this one. I use a tube cd player and it sounds way better then the unit I got rid of and I was even using a theta dac!!
I still have the original tweeters in the 1.2 and the 2.3 Looks like I need to change them!! -
Chen hasn't a clue. He doesn't use his ears. Instead, he'd rather believe a piece of paper.
Analog=audio bliss
digital=video bliss
Just my take on things."SOME PEOPLE CALL ME MAURICE,
There ya go!!
Thank you. What tube CD are you using ?
I prefer a pre with 6922s or 12AX7s with my Stratos amp. The tube preamp allows for tonal flexibility and a solid SS amp adds the damping control that I haven't found with tube amps unless uber $$$ are spent.
I also tend to find it too much of a good thing when you try to use tube source/DAC, tube preamp, with tube amps. I find it mushy and soft sounding without the clarity I require.......just my opinion of course.
Now if you are talking about high efficiency speakers....... I feel differently. The more tubes the better, to rid horns of harshness.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I have never heard tubes before but I have read that the solid state gear I am using is close to tube like. It is the Luxman M117 amp with a Luxman TP 114 pre amp. I think it is awesome. Like I said having never heard tubes I can't comment on there sound. If someone can't afford a tube set check out Luxman. It's the best solid state I have heard in two channel.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
Reluctantly delivered the Anthem to Tom today. After letting her warm up a bit and biasing the tubes, the magic happened! I listened to what he had running before and then with the amp1. NIGHT AND DAY! I'm positive that after letting the amp and cables settle in it will only sound better. Two thumbs up on the way the 1C's and the Anthem work together. I tried to get my sosns to sucker punch him so I could snag the amp and run.
No dice. So Tom, shut up,sit down and listen to the sweetness.
lightman -
The original poster qualified the task as "what you have had, not what you have read". Will you be so kind as to share what equipment you owned when you made your observations?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Ok, I'll bite and take the plunge into tubes....any suggestions for a beginner...SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Ok, I'll bite and take the plunge into tubes....any suggestions for a beginner...
Radii. Tasty little amps that pack a whollop. Look for good used ones on the bay or audiogon.
Good luck to you young padawan. It's a life altering experience. -
Good to have Russ back...
Conradicles wrote: »Good to have Russ back...
It's all about the love...
