Cable management Tubing
zx_toth
zx_toth Posts: 417
Hello
Need something to occupy me with my HT setup while I pay off some short term before I dive back into buying some upgrades ... I thought I would work on some wire management ... seems like a cheap thing to keep me occupied for the next 6 weeks as I pay off my debt.
Ive attached a picture of another polkie's wire management solution which I very much like. I emailed him about what type of tubing that was but I never recieved a reply back ... can anyone let me know what type of tubing that is. To me it looks like some 2 inch diameter industrial type stuff that can likely be bought at a local hardware store but Im not sure. Any ideas or links to products that would serve the same solution.
Thanks ahead of time.
Zsolt
Post edited by zx_toth on
  • Conradicles
    Conradicles Posts: 6,375
    edited March 2009
    Check Parts Express and you will find that same tubing in all different sizes.
    I used the 1" version, but wish I would have gone a bit smaller.
    Good stuff for cheap.
  • jgido759
    jgido759 Posts: 572
    edited March 2009
    I believe that the industry name for it is "Split Loop".
    Many sources for it (HD, Lowes, Rat Shack, on-line, etc.)
    Oh, you hate your job? Why didn't you say so? There's a support
    group for that. It's called EVERYBODY, and they meet at the bar.
    -Drew Carey
    There is a very fine line between "hobby" and "mental illness."
    -Unknown
    My DVD Collection
  • zx_toth
    zx_toth Posts: 417
    edited March 2009
    Thanks for your replies. I will look into it.
    Zsolt
  • RyanJoz
    RyanJoz Posts: 116
    edited March 2009
    I prefer spi-wrap that is cut sort of like a candy cane's stripes. Wrap it and it will expand to whatever diameter you need and it holds wires tightly together. Walmart has it in the automotive section.
    Ryan Jozwiak
    "Because music was meant to be felt and heard"
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    Samsung 40" LCD 120 Hz
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    jgido759 wrote: »
    Yep. Also check auto parts stores. That's where split loom is used the most.
    Ben
  • mantis
    mantis Posts: 17,557
    edited March 2009
    I use Velco Wrap on everything. So much better then Zip ties. I don't like the Split loom tubing as it's a pair to deal with.
    Dan
  • Conradicles
    edited March 2009
    mantis wrote: »
    Good idea. Easy to remove and re-use as well.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    I would think the tubing would cause to many wires to be run in parallel rather than perpendicular to each other.
  • Hillbilly61
    Hillbilly61 Posts: 702
    edited March 2009
    I don't think parallel runs of low voltage unshielded wires should matter much. There is relatively little power to cause induced current being picked up by the other wire. I just wouldn't bundle in AC wires with my speaker or component cabling. That could cause problems.
