Cable management Tubing
zx_toth
Hello
Need something to occupy me with my HT setup while I pay off some short term before I dive back into buying some upgrades ... I thought I would work on some wire management ... seems like a cheap thing to keep me occupied for the next 6 weeks as I pay off my debt.
Ive attached a picture of another polkie's wire management solution which I very much like. I emailed him about what type of tubing that was but I never recieved a reply back ... can anyone let me know what type of tubing that is. To me it looks like some 2 inch diameter industrial type stuff that can likely be bought at a local hardware store but Im not sure. Any ideas or links to products that would serve the same solution.
Thanks ahead of time.
Zsolt
Zsolt
Post edited by zx_toth on
Check Parts Express and you will find that same tubing in all different sizes.
I used the 1" version, but wish I would have gone a bit smaller.
Good stuff for cheap. -
I believe that the industry name for it is "Split Loop".
Many sources for it (HD, Lowes, Rat Shack, on-line, etc.)Oh, you hate your job? Why didn't you say so? There's a support
group for that. It's called EVERYBODY, and they meet at the bar.
-Drew Carey
There is a very fine line between "hobby" and "mental illness."
-Unknown
My DVD Collection -
Thanks for your replies. I will look into it.
Zsolt -
I prefer spi-wrap that is cut sort of like a candy cane's stripes. Wrap it and it will expand to whatever diameter you need and it holds wires tightly together. Walmart has it in the automotive section.Ryan Jozwiak
"Because music was meant to be felt and heard"
polkaudio RTiA9
polkaudio RT35i
polkaudio PSW 404
HK 3370
HK FL8380
HK DVD 22
Adcom GFA 5500
Samsung 40" LCD 120 Hz -
Yep. Also check auto parts stores. That's where split loom is used the most.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I use Velco Wrap on everything. So much better then Zip ties. I don't like the Split loom tubing as it's a pair to deal with.Dan
I would think the tubing would cause to many wires to be run in parallel rather than perpendicular to each other.
hearingimpared wrote: »I would think the tubing would cause to many wires to be run in parallel rather than perpendicular to each other.
I don't think parallel runs of low voltage unshielded wires should matter much. There is relatively little power to cause induced current being picked up by the other wire. I just wouldn't bundle in AC wires with my speaker or component cabling. That could cause problems.
