I was told from Pioneer CS
Toolfan66
Do not plug your SC 05, 07, 09. into a Power conditioner/ Power source.
Has anybody else heard this?
Post edited by Toolfan66 on
did they say why? Just curiousPolkFest 2012, who's going>?
so is it officially dead then?My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics -
The Ice amps need to be plugged to the wall outlet. Emotive said the same thing about there AMP's when i experianced clipping at higher volumes.
They had me hold the power button in for about 3 minutes with the unit unplugged, They said it drain's excessive energy or something to that effect. a few month's ago i was having exsessive noise coming from my plasma tv in my bedroom they had me do the same thing, and it worked. I guess i don't understand it but i am up and running so i don't care at the moment. LOL
Glad you have it up and running!
All though I have (had) my Pioneer Elite 92 hooked up to my Power Center, along with my XPA-3 and experienced no issues. I hope I don't have any trouble with the SC-07 and XPA-3 hooked up the same way. I only have one outlet near my gear, and really no way to plug them both directly into the wall. I could probably plug one directly into the wall, but I would need the other plug for my Power Center for all my other gear.
Anyway, I can't wait to here your impressions on your new toy!
TOOL, you are one MATRIX freak! I couldn't figure out which thread should I post...:p
It's all good, may wanna plug your elite back to your PC and just customized the setting to be ON/ active all the time. This should eliminate the unprotected connection from your wall. u got the PC, USE it....Otherwise make PIONEER ELITE be liable if there's a surge/ voltage spike incident...:cool:Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
OK i got another problem. When i use the Y connector for my SUB's i am getting a buzzing sound. is this normal? it would not seem like it to me.
Are you running multiple subs? Are the all the same kind? Are they plugged into the same outlet/line?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yes i have the DSW PRO 500, and 600. i am using a Y adapter. -
Are they on the same outlet?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
No, i have one in the back of the room, and one in front. the one in back i pluged into another outlet, and it stopped.
I did not have that problem with the Yamaha but it had to sub out's. not sure why that would make any differance. -
TOOLFORLIFEFAN wrote: »No, i have one in the back of the room, and one in front. the one in back i plugged into another outlet, and it stopped.
I did not have that problem with the Yamaha but it had to sub out's. not sure why that would make any difference.
More important question might be were the AC outlets on the same circuit? Wonder if you have a ground loop type problem.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Hi Tool.
Is the buzz coming from one or both of the subs?
If you have the Y splitter connected at one of the subs, try running the Y out of your reciever's sub out instaed.
Mike____________________________________________
Home Theater 32"LG LCD; Comcast; 7.1 Onkyo 805; Fronts: Polk M50s; Center: Polk CS2; Sides: Polk M40s; Rear: B&W LM1s; Subs: (2) Sony 12" x 100w; Samsung 1500BDP; Toshiba A-2 HD-DVDP.
PC stereo: Viper custom PC: Windows XP; ASIO4ALL; JRiver Jukebox> Pop Pulse USB to S/PDIF conv> Monarchy DIP > Musiland MD10 DAC > Parasound 2100 pre> Aragon 4004 MKII amp> Dali Ikon6 towers; Sunfire True Sub; PSA Duet, Ultimate outlet and Noise Harvestors. -
TOOLFORLIFEFAN wrote: »Do not plug your SC 05, 07, 09. into a Power conditioner/ Power source.
I would like to know who said this. This is simply not true but true from a certain point of view.
Ice amps or not , any device plugged into a surge/ Conditioner needs to have the correct amount of voltage to work correctly. If you current limit your device , it will not perform correctly.
So Your or Pioneer's point is correct from this point of view. Now if you have a high end Surge/ Conditioner designed for High current devices like amp or high current receiver, you will have NO problems even at extended listening at Reference levels.
I use all Panamax Surge protector/ line conditioners. I personally own the M5500ex which is top of the line a few years back . I plug everything into it with no Current limitations and I have a Rotel RMB1095 pulling juice from it. No problems even with my hard to drive speakers at 4 ohm load and all in the 80's db. They tend to suck the life out of anything that doesn't have much to give. The power center delivers plenty of power to supply all my gear correctly and then some. This also includes a Rear Projection tv.
I do not think plugging your receiver directly into a outlet is a wise idea. Now it is unprotected and uncorrected. Your getting **** power.
Do yourself a favor and get a high quality Power center like a Panamax M5400 or 5500. This is what I would sell you to go with you high end receiver. Also do your homework on the Panamax line. You will see there is no reason to buy anything else.
DanDan
I've got a pair of Parasound HCA-1500 power amps plugged into the high-current outlets on my Panamax 5100EX and I don't have any problems with current limitations impacting the sound of the amps. I second the Panamax recommendation, and also recommend PS Audio's units.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Dan
I will do Dan. it makes no sense to me as well, But now i am very nervous to plug it in now that i am up and running. I want it plugged in trust me, i don't like it unprotected.
Thanks,
Larry. -
TOOLFORLIFEFAN wrote: »I will do Dan. it makes no sense to me as well, But now i am very nervous to plug it in now that i am up and running. I want it plugged in trust me, i don't like it unprotected.
Thanks,
Larry.
The 07 will maintain its setting even if unplugged for a while so nothing wrong in trying. Worst case, it won't turn on. I suggest Panamax or Monster, check A'gon as you can buy these for good prices.Shoot the jumper.....................BALLIN.............!!!!!
