Magnet glue for speaker repair
ben62670
ben62670 Posts: 15,969
edited June 2010 in DIY, Mods & Tweaks
Anyone have any solid advice on an epoxy/glue for repairing a shifted magnet. This is a non Polk driver, and the threaded steel plate that is glued to the magnet structure has shifted.
Ben
Ben
Post edited by ben62670 on
  • ben62670
    edited March 2009
    Found just what I am looking for. It is a super glue type adhesive that withstands high heats, and does not fracture like regular super glue:)
    http://www.instantsolutions.loctite.com/stronger_Toughened.htm
    Ben
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    Ben, what about JB weld ?
  • ben62670
    edited March 2009
    thsmith wrote: »
    It's funny you mention that. We need something very low in viscosity to adhere the plate to the magnet, but we are planning on running a ring of JBweld around the circumference.
    Ben
    Ben
  • mmadden28
    mmadden28 Posts: 4,283
    edited June 2010
    ben62670 wrote: »
    Hey Ben, what was it that you ended up using? The link above is dead.
    Was it this?
    ____________________
    Pool: Atrium 60's/45's
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    ben62670 wrote: »
    Ben
    I'm doing a update on the SDA 2b's. While I'm in there would it be a good idea to go ahead and do this JB weld thing to the MW's?
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • HB27
    HB27 Posts: 1,518
    edited June 2010
    The JB Weld is foolproof. DO ALL the seams from the frame to the outer edges of the mag structure.. $5 for enough to do a dozen or more drivers.
    It sets up quick so only mix enough to do about 4 drivers at a time.
    Clean surfaces are a must. NON residue cleaner.
  • helipilotdoug
    edited June 2010
    OK, thanks, will do. I'm going to have lots to do with all the tweaks etc I'm doing!
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
