Magnet glue for speaker repair
ben62670
Anyone have any solid advice on an epoxy/glue for repairing a shifted magnet. This is a non Polk driver, and the threaded steel plate that is glued to the magnet structure has shifted.
Ben
Ben
Ben
Ben
Post edited by ben62670 on
Found just what I am looking for. It is a super glue type adhesive that withstands high heats, and does not fracture like regular super glue:)
http://www.instantsolutions.loctite.com/stronger_Toughened.htmPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Ben, what about JB weld ?Speakers: SDA-1C (most all the goodies)
It's funny you mention that. We need something very low in viscosity to adhere the plate to the magnet, but we are planning on running a ring of JBweld around the circumference.
Ben -
Hey Ben, what was it that you ended up using? The link above is dead.
Was it this?____________________
Pool: Atrium 60's/45's -
Ben
I'm doing a update on the SDA 2b's. While I'm in there would it be a good idea to go ahead and do this JB weld thing to the MW's?Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
helipilotdoug wrote: »I'm doing a update on the SDA 2b's. While I'm in there would it be a good idea to go ahead and do this JB weld thing to the MW's?
The JB Weld is foolproof. DO ALL the seams from the frame to the outer edges of the mag structure.. $5 for enough to do a dozen or more drivers.
It sets up quick so only mix enough to do about 4 drivers at a time.
Clean surfaces are a must. NON residue cleaner. -
OK, thanks, will do. I'm going to have lots to do with all the tweaks etc I'm doing!Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
