Help in adding an AUX to a factory radio
mmadden28
mmadden28 Posts: 4,283
edited March 2009 in Car Audio & Electronics
Hopefully a simple issue:
I have an AUX in on my car that I connect my iPod to (headphone jack) and it works well. For some reason, when we bought the Trailblazer, we never checked to see if had an AUX in-I guess we just assumed all new cars had one. Well it doesn't. :(
Its a 2007(pretty sure) Chevy Trailblazer with the factory radio with XM and a 5 or 6 CD changer. I believe the speakers are Bose.
So far some of the stuff I found to enable an AUX or iPod in would disable the CD Changer/Player and that's not an option. An FM modulator is also an absolute NOT HAPPENING.
The radio's control panel has a button labeled AUX, but there is no AUX in to connect to.
Can anybody tell me if an AUX exists for my vehicle/radio model and all I have to do is connect to it somehow? Or suggest some other way to enable me to add an AUX in or iPod interface? Its a Lease so replacing the Head Unit is probably not going to happen (unless its a trivial thing).
Thanks!! :)
____________________
Pool: Atrium 60's/45's
Post edited by mmadden28 on
  • exalted512
    exalted512 Posts: 10,734
    edited March 2009
    There are things out there called isimple units (i believe). They run about $200 but should work for you. Not sure how much you were looking to spend.
    -Cody
  • ben62670
    ben62670 Posts: 15,969
    edited March 2009
    Cody what do you think of the FM transmitters? Anything any good?
    Ben
  • shack
    shack Posts: 11,154
    edited March 2009
    This should work. It is designed to work with the Chevy Bose systems. Crutchfield is usually good about adding detailed installation instructions with their gear.
    http://www.crutchfield.com/p_541ISGM73/Peripheral-iPod-GM-Interface-Kit.html?tp=120
  • exalted512
    edited March 2009
    ben62670 wrote: »
    I'd rather staple my eye lids shut than use on those.
    -Cody
  • ben62670
    edited March 2009
    exalted512 wrote: »
    -Cody
    LOL I guess they are where they were when I last looked at them.
    Ben
    Ben
  • exalted512
    edited March 2009
    ben62670 wrote: »
    Ben
    Well, the ones from like 5 years ago are pretty good. Then the gov't stepped in and said you cant have a signal stronger than XX amount. So then they sucked. Then a few got smart and are plugging directly into the antenna on the back of the radio...which are decent...but still with the lack of very low and very high frequencies (typical FM), but at the expense of the reception of every other station.
    -Cody
  • mmadden28
    edited March 2009
    Thanks all-I'll check the iSimple and that Crutchfieled offering out. Actually looks like they both may be the same manufacturer.
    I'm not sure how much I'd be willing to spend honestly. I guess it depends if it offres additional features. If its just providing an Aux in-I don't want to spend too much. $150 is probably OK for what Shack linked to.
    Anything is better than an FM transmitter. I'd rather tune to an empty AM station. ;)
