Upgrading tweets on 2.3TL
solidclub
solidclub Posts: 39
edited March 2009 in Vintage Speakers
Hey guys,
I have decided to heed some early advice from the forum and
upgrade the tweets on my 2.3TLs.
What are the current and appropriate options from Polk for
doing this? Also do I have to do them all at once, or can I
do it progressively?
Awaiting your advice,
Alex.
  • NJPOLKER
    NJPOLKER Posts: 3,475
    edited March 2009
    No doubt about it, all at one time.
    I do believe you need to order RDO-198's at about $50.00 each from Polk customer service. That cost is for members so be sure to tell them you are a member here.
    Good luck
  • bsoko2
    bsoko2 Posts: 1,449
    edited March 2009
    I did my 2.3's (not TL) and it did make a diff. My next step is to do the crossovers.
    Bill
  • zarrdoss
    zarrdoss Posts: 2,562
    edited March 2009
    I replaced the ones in my 2.3tl's with rdo 198 and they sound much better, and definitly all at the same time.
  • solidclub
    solidclub Posts: 39
    edited March 2009
    So it looks like I'll be replacing all the tweets!!
    I'm waiting for a reply back from Polk re: the RD0 - 198's.
    I'm currently experiencing a bit of intermittent crackle in the left
    top tweet, so what better excuse to change over?
    Has anyone fried a tweet by putting too much power through
    it?
    Thanks again,
    Alex.
  • NJPOLKER
    edited March 2009
    Yup
    Back in the day, late 70's, when I over drove my receiver, which is long gone.
    What are you using to power those bad boys?
  • zarrdoss
    edited March 2009
    The top left tweet in my 2.3 tl's would shut off and I figured it was the cap on the x-over so I resoldered it and it works fine so just replacing the tweets may not take care of the problem. I would switch it out with another one first and see if that takes care of the crackel.
