Common ground amp & SDA's
Bikerduck
Bikerduck Posts: 43
edited March 2009 in Vintage Speakers
Does anyone know if the Kenwood KA-801 is a common ground amp?
I would like to try out that amp with my SDA's but don't want to blow the speakers :D
MAIN:Kenwood M2a,C2,Sansui TU-517,Yamaha CDX-1100,Kenwood GE-1100,Nakamichi BX150,SDA 2a,Kenwood Ka-801,HPM-100
DEN:Kenwood Basic M2,C2,T1,Yamaha CDX-1100,Parasound DHX 600,ADS 1090
OFFICE:Kenwood Ka-8300,Technics SL-P770,Nakamichi BX150,Polk Monitor 7b
BEDROOM:Kenwood Ka-7100,KT-6500,KX-1030,Teac Reference 500,Monitor 10b
Yamaha CA 810,CT 810,Yamaha CDX-1060,Monitor M 5b
Kenwood Basic M1a,C1,Yamaha CDX-930,KA-77,KT-313,KA-3500,KA-5700,Technics SU 8600,ST 8600
Post edited by Bikerduck on
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    +1, I have ran a TFM-25 with great results on my SDA-1Cs and currently running a TFM-45 with even better results. I would not pay more for a TFM35 orver a 25 and same for 55 over a 45.
    Try to find one recently service with paper work for proof if possible. I highly recommend Rolland at Carveraudio for any service work.
    heiney9 Posts: 25,497
    edited March 2009
    I see you have a KA901, probably the same design as KA801. If you have the amp already you can use a VOM to measure between the (2) negative speaker terminals (with the amp off of course). This will tell you if the amp has a common ground config.
    p.s. Why is it whenever someone asks a specific question about a specific piece of equipment people always chime in "you should get this". It gets old <end rant> :)
  • erniejade
    erniejade Posts: 6,321
    edited March 2009
    I have a kenwood ka8006 top of the line from 1973 that amp sounds great!!!! The one you have is a bit newer then mine but should still sound as good if not better as it is a different design.
    Now are you going to use the connect cable on your SDAs'? If not, then you do not have to wory.
    If you do though, I thought that one was a dual mono... If people do not know on here, i would post on audiokarma. they have some big kenwood fans there.
  • Bikerduck
    Bikerduck Posts: 43
    edited March 2009
    I did read that some int. dual mono amps are common ground but the 801 is not one of them.
    I am getting tired to the point of selling the SDA's. I got 12 amps and can only use 2 M2a's with them, the rest is either not common ground or don't have enough wattage plus they are a pain to place right.
    I like to switch things around :D
    F1nut Posts: 52,000
    edited March 2009
    Simple solution, build yourself an AI-1.
    Oops, just noticed that you have 2A's, never mind.
  • george daniel
    george daniel Posts: 12,096
    edited March 2009
    in that case, your only hope may be a tube amp,,say 40-75 watts of sweetness.
  • Schurkey
    Schurkey Posts: 2,122
    edited March 2009
    When I contacted Polk (about 1992) about using an Aragon 4004 with SDA 1B speakers, they suggested building a short jumper wire with appropriate terminations on each end to connect the black (-) speaker connectors together.
    As long as the amplifier isn't bridged, you've then guaranteed that it is common ground.
    Later, I contacted Aragon and they told me the "Dual Mono" 4004 is in fact separate on the positive side (including separate power transformers and storage capacitors for each channel) but the ground side was common--and so I then removed the jumper wire between the negative speaker posts.
  • davidfmartin
    davidfmartin Posts: 106
    edited March 2009
    Correct me if I am wrong but I thought all you had to do to test if an amp is common ground is to take a multi meter and check continuity between the negative (black) speaker posts on the amp?
    edited March 2009
    Schurkey wrote: »
    Just to keep this factual.............not all non-common ground amps can have their neg terminals tied together. It's always best to contact the manufacturer to see if this is possible. There are even a few mono bloc's that can have their terminals tied, but ALWAYS check with the manufacturer or someone else with the knowledge that has done it before.
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2009
    You need better than continuity, it needs to be a straight short for it to be common ground.
    Adding a jumper could, in some cases, cause trouble. Not something you should try just **** and giggles.
  • Systems
    Systems Posts: 14,872
    edited March 2009
    ShinAce wrote: »
    In some designs there may be a few tens of ohm's resistance .A resistor is sometimes added to isolate the grounds of both channels from each other and chassis ground.It would still be safe to strap the grounds.
    Testing
    Testing
    Testing
  • bsoko2
    bsoko2 Posts: 1,449
    edited March 2009
    The other choice is to build a "Dreadnaught" (http://www.polkaudio.com/forums/showthread.php?t=74472&highlight=dreadnaught). A DIY job is 150 or so and to have one built is more. ben62670 on this forum can do it if you want one.
    Bill
  • danger boy
    danger boy Posts: 15,722
    edited March 2009
    heiney9 wrote: »
    what kind of settings and what kind of readings will you get on the VOM? I need to find this out also in my amp. I don't know anything about VOM.. so please explain it like you were talking to a 5 yr old. ;)
    PolkFest 2012, who's going>?
  • Systems
    edited March 2009
    danger boy wrote: »
    Use the ohm's setting and place the meters probes on the 2 negative binding posts.If the resistance reads less than say 20ohm's your good.
    Testing
    Testing
    Testing
  • Systems
    edited March 2009
    bsoko2 wrote: »
    Bill
    According to this poster it will not work with that speaker.
    Testing
    Testing
    Testing
  • Schurkey
    edited March 2009
    Correct as far as I know provided "continuity" means "very low resistance". Lower is better. Not everyone has an ohmmeter, though.
    heiney9 wrote: »
    I respect your opinion; and in truth I am NOT an electrical engineer...but...if the amp is not bridged, how can it be hurt by a jumper wire across the negative terminals?
    I'm not saying you're wrong. I just don't understand the problem if the amp isn't bridged. I won't state an opinion about strapping the negative terminals of two non-bridged monoblocks except to say that some folks have done it and not burned their houses down--so you're correct, it must work in at least some instances!
    If the amps ARE bridged, there will be hell to pay if the negative terminals are strapped together!
  • Systems
    edited March 2009
    Schurkey wrote: »
    It shouldn't be a problem with any CG unit,even with amps using dual mono construction that have completely separate power supplys for each channel.
    Testing
    Testing
    Testing
  • ShinAce
    edited March 2009
    Designers and engineers almost always use the metal case as a ground or earth ground. There is the odd chance that this has not been done and the grounds are not common. For this exotic amp, you might be able to jumper the grounds, but do not short them to the case.
    I'd guess that over 95% of amps are common ground with another 4% that can be jumpered.
    Again, ditch the continuity and read resistance. Touch the probes together and you'll get maybe 0.2 ohms. This is the resistance of the probes. Now read between the negative terminals. If you get 0.2 or 0.3 ohms, it's common ground.
    edited March 2009
    Schurkey wrote: »
    I'm not either, but I do believe if an amp is truly a balanced design the neg terminals cannot be strapped in all instances. For instance Adcom 55xx series CAN be strapped since they are not common ground; Pass Labs "X" series amps CANNOT be strapped to create a common ground.
    Yes this is correct as far as I know......some can some cannot.
    If they are stereo amps run in bridged mono they CANNOT.....
    Always check with the manufacturer first
  • ShinAce
    edited March 2009
    Schurkey wrote: »
    My prescription must be too strong.
    To bridge two channels, you must first short the negative terminals and take your signal from the positive terminals. A bridgeable amp is already common ground.
    edited March 2009
    ShinAce wrote: »
    It is in stereo mode but certainly isn't as a mono block. How can 2 completely separate "black boxes" share a common ground when they aren't even connected to each other?
    If you hook up bridged stereo amps and run them as mono bloc's with SDA's there will be damage to amp, speakers, or both. I guarantee it. I don't know of any bridged mono blocs that can have their negative terminals strapped together between the left and right mono bloc.
  • Systems
    edited March 2009
    ShinAce wrote: »
    An amp will be common ground when the neg speaker terminals and power supply grounds are tied together.They may or may not be connected to chassis ground.
    Even amps with full time bridged output stages ( not with a switch) can have a conection to chassis ground the difference being that the neg speaker terminal is not connected to the power supply or star ground so there is no problem doing so.
    Testing
    Testing
    Testing
  • Systems
    edited March 2009
    ShinAce wrote: »
    The neg terminals will already be connected internally.But when you bridge you use the pos terminals only,so it is no longer common ground as both outputs will be hot.
    Testing
    Testing
    Testing
  • shadowofnight
    shadowofnight Posts: 2,735
    edited March 2009
    This wil help to visualize the outputs....
    The first rule of Fight Club is you don't talk about Fight Club
  • ShinAce
    edited March 2009
    GV#27 wrote: »
    I guess that's where I go astray, terminology. I would not speak of a bridged amp as common ground, since you're running it without a ground. A monobloc amp might still have a ground. However, I don't consider my bridged stereo amps as monoblocks.
    edit: both amps shown above are bridgeable. The limitation within the second layout is that the input signal hasn't been inverted for one channel.
  • Marty913
    Marty913 Posts: 760
    edited March 2009
    Somewhere between post #20 and post #27 my head exploded.
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
  • Systems
    edited March 2009
    ShinAce wrote: »
    Using a bridgable amp in non bridged mode, both of the negative terminals and power supply grounds will be at the same potential or common.
    When you bridge it the negative terminals are still common(connected) but the negative half of the waveform is taken from the second channels pos terminal which is not at ground potential.There is a ground just neither of the output terminals are connected to it.
    You cannot strap the outputs of two bridged amps together,but you can strap the outputs of two mono blocks that do not have bridged/balanced output stages because when strapped their grounds will all become common.:D
    Testing
    Testing
    Testing
  • Bikerduck
    Bikerduck Posts: 43
    edited March 2009
    I measured the resistance today between the 2 neg outputs and it came to 01.6 on the 200 ohm setting. According to some posters here, that would mean it's a common ground. How can that be?
    Donald
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    Bikerduck wrote: »
    Donald
    So would that be 1.6 ohms or 160 ohms?
  • Systems
    edited March 2009
    Bikerduck wrote: »
    Donald
    If you are getting 1.6 ohms then it is common ground.
    As Shinace pointed out earlier the probe leads will have a small amount of resistance as will any wiring that may be used to connect the neg terminals internally.Touching the probes together will tell you how much of that 1.6ohms is in the test leads.
    Testing
    Testing
    Testing
