Common ground amp & SDA's
This guy says it's a True Dual mono design.
http://www.canuckaudiomart.com/details/11654-kenwood_ka801_highspeed_integrated_amplifier
I'd stay away from it.
Get yourself a Carver TFM:
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&from=R40&dfsp=32&satitle=carver+tfm&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=07306&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&sadis1=100&fpos1=07306&lsot1=&fsop=32%26fsoo%3D2&fgtp=&sadis2=100&fpos2=07306&lsot2=
Are you asking how a dual-mono design can be common ground?I measured the resistance today between the 2 neg outputs and it came to 01.6 on the 200 ohm setting. According to some posters here, that would mean it's a common ground. How can that be?
Donald
First Guess: Just like the Dual-Mono Aragon, the ground side is common. Only the positive side is separate. -
Correct,my Bryston's are dual mono's but the grounds are tied together on the power supplies PC board.First Guess: Just like the Dual-Mono Aragon, the ground side is common. Only the positive side is separate.Testing
Testing
Testing -
Then it should be save to use it with the SDA's. I will hook it up this week and see what happens.
Thanks everyone for the help.
DonaldMAIN:Kenwood M2a,C2,Sansui TU-517,Yamaha CDX-1100,Kenwood GE-1100,Nakamichi BX150,SDA 2a,Kenwood Ka-801,HPM-100
DEN:Kenwood Basic M2,C2,T1,Yamaha CDX-1100,Parasound DHX 600,ADS 1090
OFFICE:Kenwood Ka-8300,Technics SL-P770,Nakamichi BX150,Polk Monitor 7b
BEDROOM:Kenwood Ka-7100,KT-6500,KX-1030,Teac Reference 500,Monitor 10b
Yamaha CA 810,CT 810,Yamaha CDX-1060,Monitor M 5b
Kenwood Basic M1a,C1,Yamaha CDX-930,KA-77,KT-313,KA-3500,KA-5700,Technics SU 8600,ST 8600 -
Strap the negative terminals together on the amp if you are getting a low ohm reading. I didn't on my GFA-585(dual mono's), and blew the input resistors. If your amp can run common ground then you have no worries of strapping the negs together. It is very cheap piece of mind.
Ben
