TT pre-amp a necessity?
Norm Apter
SteveinAZ's thread got me thinking...is a separate tt pre-amp a necessity for hooking up a tt, even if one's my pre-amp is equipped with Phono RCA posts (I've never hooked up a tt but I just checked the back of my pre and found that there are two RCA posts labeled "AUX / phono"
Is that sufficient for hooking up a tt, or would I need a separate tt pre?
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
HT
Denon 2808ci AVR
Post edited by Norm Apter on
You didn't read the book?
If you are talking about your Parasound P3, it has one input that can be used for moving magnet (MM) phono cartridges, so you wouldn't necessarily need one as long as you were using a normal MM cartridge.
Yes, I am talking about that one.
Thanks for the information.2 Ch.
HT
Denon 2808ci AVR
