Does this receiver exist?
Veccster
I am looking for a receiver to hook up my parents home theater system. They have 5.1 speakers, a DVD player, cable box and a HD TV.
Ideally, I would like to hook everything up to the receiver and have one wire going to the TV. The problem is that each component has a different wiring method.
The DVD has component.
The Cable Box has HDMI or component.
The TV accepts everything but S-Video.
What I have found with their current receiver, is that 'component in' only runs 'component out'...similarly, 'HDMI in' only runs 'HDMI out'...which means I need to use 2 video inputs on my TV.
I want to do this with only one video input used on the TV (HDMI). All other devices will be hooked up using the other wires but the picture is tranferred to the TV with the HDMI.
I hope this makes sense and am only wondering if it exists or is common.
Post edited by Veccster on
You need an AVR that does full internal switching. How much do you want to spend? I think we could come up with something at your price point.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Since the HD box has component outputs, why don't you use those?
HD broadcast is 720p/1080i native and should go happily through the component outputs.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
